HELP car wont start
Old Oct 3, 2006 | 08:54 AM
adeline's Avatar
Default HELP car wont start
I blew the radiator return hose and now I cant get it to start no matter what I try.
Old Oct 3, 2006 | 08:59 AM
65stang90crx's Avatar
Default Re: HELP car wont start (adeline)
I know this might sound stupid but try and bleed the air out of the lines in the top hose by the block. Crack open the bleeder and squeeze the tube, tighten.
Old Oct 3, 2006 | 09:11 AM
adeline's Avatar
Default Re: HELP car wont start (65stang90crx)
My car will not crank at all, the fuel pump run but, no crank
Old Oct 3, 2006 | 09:16 AM
Ahh that changes things a bit. Details and background are a big help. Are you pushing in the clutch? lol stupid I know but I have to ask.
Old Oct 3, 2006 | 09:22 AM
adeline's Avatar
sometime, I have an 88 hf and some put an remote starter in
Old Oct 3, 2006 | 09:28 AM
Craigp23usa's Avatar
when you blew the rad hose did the engine stop on its own??? buy a new motor.
chek and make sure you did not pull the 12v solenoid wire off the starter cause it comes off easy.
if you want to see if the engine is seezed or not short + batt to that 12v signal when in neutral.
If the car was running before you blew the hose it should run now.
Hmm since Im the only one responding to this......I would suggest making sure that the remote starter isnt interfering with anything and/or is hooked up right.
Old Oct 3, 2006 | 09:31 AM
adeline's Avatar
I took it off about a year ago
Old Oct 3, 2006 | 09:37 AM
you took what off a year ago?
Old Oct 3, 2006 | 10:04 AM
adeline's Avatar
Default Re: (Craigp23usa)
remote start
Old Oct 3, 2006 | 05:46 PM
Default Re: (adeline)
Ok at this point if you arent going to give important information or any info at all about the problem, you will have to figure this one out on your own! \ /
Old Oct 3, 2006 | 06:27 PM
Default Re: (65stang90crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 65stang90crx &raquo;</TD></TR><TR><TD CLASS="quote">Ok at this point if you arent going to give important information or any info at all about the problem, you will have to figure this one out on your own! \ / </TD></TR></TABLE>
i agree
Black-EK_EX
Apr 11, 2018 07:26 PM
wnp94
Mar 13, 2014 12:22 AM
haze808
Jun 25, 2010 04:16 PM
Fresh Ej2
26
Apr 2, 2009 06:19 PM
CiViC I2aCeI2
Mar 12, 2006 03:53 PM
