b18c5 with jun stage 4 camshafts
Old Oct 3, 2006 | 05:23 AM
christion's Avatar
Default b18c5 with jun stage 4 camshafts
Hi, I just needed some opinion from you guys.
I have a 94 civic hatchback with a b18c5 engine with jun stage4 cams, 81.25mm p73 pistons and a ported b16 head. I just recently have a tri-angle valve job done.
I'm still using the stock 240cc injectors. Are these OK or do I have to change them to a 280cc / 310cc. On low rpm there is a lot of power, but as soon as the vtec kicks is the car holds back. Thanks!!
Old Oct 3, 2006 | 05:26 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: b18c5 with jun stage 4 camshafts (christion)
Holds back? Do you have this setup tuned? Or are you using a stock ECU? Sounds like your leaning out.
Old Oct 3, 2006 | 06:39 AM
poison's Avatar
I would go for some 310s. But for sure the first thing I would go is get it tuned.
Old Oct 3, 2006 | 04:20 PM
christion's Avatar
Default Re: b18c5 with jun stage 4 camshafts (JDM_Ej)
I think so, because when I checked the spark plugs they were like white.
Old Oct 3, 2006 | 04:27 PM
YodajdmEK4's Avatar
You are runnin really lean!!
Old Oct 3, 2006 | 04:35 PM
BuiltforSin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by christion &raquo;</TD></TR><TR><TD CLASS="quote">I think so, because when I checked the spark plugs they were like white.</TD></TR></TABLE>
get some larger injectors asap
Old Oct 5, 2006 | 12:10 PM
EJgsr's Avatar
Default Re: b18c5 with jun stage 4 camshafts (mugenej8power)
or just a retune.
Old Oct 5, 2006 | 12:16 PM
cambopheonix56's Avatar
Default Re: b18c5 with jun stage 4 camshafts (sohcpowa)
Get 210's and tune it asap or watch your motor go bye bye.
Old Oct 5, 2006 | 01:46 PM
christion's Avatar
Default Re: b18c5 with jun stage 4 camshafts (cambopheonix56)
How do you mean 210's. stock is 240. Or do you mean 310's
Does somebody there has a similar setup!! What size injectors is recomended??
Old Oct 5, 2006 | 01:57 PM
MajorPayne's Avatar
yeah i would go at least 310s or larger, plus if you havent been tuned, you will definitely, the stock fuel map isnt going to be able to make the most of those cams, as they are pretty big
Old Oct 6, 2006 | 07:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by christion &raquo;</TD></TR><TR><TD CLASS="quote">How do you mean 210's. stock is 240. Or do you mean 310's
Does somebody there has a similar setup!! What size injectors is recomended??</TD></TR></TABLE>
Sorry I meant 310's
christion
Jul 31, 2007 02:06 PM
PY TYPE R 483
May 14, 2006 06:02 AM
Christofferson
Jan 10, 2006 07:28 AM
SLeePeR012
11
Jun 14, 2003 03:41 PM
TypeR 599
Dec 9, 2002 06:00 PM
