Evo Magazine (UK) names Integra Type R "greatest front-drive car ever"
Old Oct 3, 2006 | 12:08 AM
White98LS's Avatar
Default Evo Magazine (UK) names Integra Type R "greatest front-drive car ever"
Evo Magazine (http://www.evo.co.uk/), a highly regarded and respected publication in the United Kingdom with a distinct focus on "The Thrill of Driving", gathered their 15 favorite FWD driver's cars in automotive history in their September 2006 issue. The top 15 cars were (from oldest to newest):
1982-84 VW Golf GTI mk1
1988-91 Peugeot 205 GTI
1989-95 Lotus Elan
1992-96 VW Corrado VR6
1993-96 Renault Clio Williams
1994-96 Peugeot 106 Rallye
1995-2005 Fiat Barchetta
1996-2000 Honda Integra Type-R
1997-2002 Ford Puma
1998-99 Peugeot 306 Rallye
2002-03 Ford Focus RS
2004-present VW Golf GTI mk5
2005 Renault Clio Trophy
2007-present Mini Cooper S Works GP
2007-present Renault Clio 197
Remarks on the Integra Type R from the initial round, before determining 6 finalists:
"There has never been a more focused, less compromised front-drive coupe than the Integra. From the moment you drop into its low-slung, huggy seat, clock the 8000rpm redline and give the titanium-topped gearlevel an exploratory waggle, you know that this could be a very special car. It doesn't disappoint.
'Unbelievable,' blurts Bovingdon. 'Superb engine, gearbox and brakes, and a simply awesome chassis.' Oh yes. Immediately obvious is the quality of the steering: its smoothness, its meatiness, its keenness. This Honda exudes quality and precision, and the limited slip diff subtly enhanves the traction of its relatively slim tyres. 'The more revs you pile on, the more neutral it seems to get,' adds Bovingdon. Meaden is more succinct: 'It's fantastic.'"
The 6 finalists are chosen:
"It's been a long time since I've driven an Integra, but it's like seeing an old friend. You sit low, arms and legs outstretched, rather than hunched over the wheel. Everything feels comfortable and perfectly placed, from the tactile titanium gearknob to the fat-rimmed steering wheel and alloy pedals. Longer, lower, and altogether more rakish than the boxy hatchbacks, when you drop into the coupe's classic Recaro you know you're in a different breed of car.
The VTEC motor sounds tinny on start-up, a brittle zing with no apparent guts and a less than sharp throttle response at low revs. The gearshift is delicious: short and precise, even in this 60,000-mile example.
The steering has surprising weight, despite power assistance, but there's a slight numbness to the feel for the first degree either side of dead centre. However, it's soon infused with super-detailed and ever-changing feel as you apply more lock, a constant flow of granular, textural feedback flowing through the rim.
Drive the Integra slowly and it feels a bit flaccid. You could almost wonder what all the fuss is about, but once that firecracker engine ignites, the humble Honda is transformed into a humdinger. It thrives on high revs, that classic VTEC kick hitting home at 6000rpm, from which point the fizzing four-cylinder emits a magical howl as the tacho needle homes in on and then passes 8000. It's like driving a real exotic: the super-high-revving engine, rifle-bolt gearshift, rigid bodyshell and incredibly controlled suspension melding to deliver an sensationally effective performance.
It's a frantic recipe, but there's so much more to the Integra than the binary character we've become used to in subsequent hot Hondas. You need to work the car hard, but it rewards you with a rich flow of organic feedback, tackling this unforgiving road with rare subtlety and composure, while at the same time keeping you involved every inch of the way.
Grip levels are miraculous on such modest rubber, and the limited-slip differential generates tremendous traction. There's no torque-steer to speak of, but then it's hardly rippling with lb ft, which probably explains it. Nevertheless, the combination of taut but supple suspension, a terrifically effective diff, abundant grip and no torque-steer leaves you with one of the purest and least corrupted front-drive helms ever.
As much as becomes abundantly clear as we tackle the corner for the final time. Still accelerating hard in fourth gear, at around 80mph, the Integra doesn't need any cajoling, coercing, or convincing. It simply turns in, biting hard into the tarmac, with a level of adjustability and fluidity that takes your breath away. It ignores the surface change, dances across the camber, and as momentum and lateral force begin to push the Bridgestones beyond even their prodigious adhesive limits, the Type-R enters a completely different realm.
You feel the nose hint at runing wide, but as you apply a little more lock the diff really begins to work, and in so doing brings the tail increasingly into play, to the point where the car actually adopts a mild, natural oversteer stance. Three wheels working hard, one barely in contact with the road, the Integra scythes through at unabated speed, no wasted effort, no scrappy corrections, just searing pace and total involvement.
It's a car as sweet and all-consuming as any I've experienced at any price, and as pure and focused in its own way as any Porsche RS. Forget the accolade of greatest front-wheel-drive car. The Integra Type-R ranks as one of the truly great drivers' cars of any kind."
The 6 finalists listed above are in finishing order. The Integra Type R is the greatest FWD car ever made!
Old Oct 3, 2006 | 02:11 AM
uNF$@#!'s Avatar
Default Re: Evo Magazine (UK) names Integra Type R "greatest front-drive car ever" (White98LS)
one could argue, that there isnt much competition to take over the ITR if its merely FWD based
Old Oct 3, 2006 | 04:57 AM
crxgator's Avatar
Default Re: Evo Magazine (uNF$@#!)
what, no crx...booo...
Old Oct 3, 2006 | 07:35 AM
John Z's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White98LS &raquo;</TD></TR><TR><TD CLASS="quote">
The 6 finalists listed above are in finishing order. The Integra Type R is the greatest FWD car ever made!</TD></TR></TABLE>
so the R came in 6th?
Old Oct 3, 2006 | 07:44 AM
Big Phat R's Avatar
Hooray - we win!
(as if we didn't already know this already...)
Old Oct 3, 2006 | 07:47 AM
BERT-O's Avatar
Eh....doh!!! lol
330R's Avatar
https://honda-tech.com/zerothread?id=1707610
https://honda-tech.com/zerothread?id=1734265
Cool of you to type up the quotes and results, though.
330R, who is looking over at his copy right now.
Old Oct 3, 2006 | 07:48 AM
RTW DC2R's Avatar
its been said many times before, but once more wont hurt
nevAR l0se
Old Oct 3, 2006 | 07:54 AM
PhoenixDownVII's Avatar
Default Re: (RTW DC2R)
Where's the new Prelude? Don't they do pretty well? How about the Celica GT-S? I've heard great things about those two vehicles.
Otherwise, I'd say they got it right on! However, the way they address every praise as such it'll make you love any car they're talking highly about lol.
After much seat time in a Type R I must agree
Old Oct 3, 2006 | 08:19 AM
T3k C's Avatar
+1 for TYPE R!!
Old Oct 3, 2006 | 08:34 AM
White98LS's Avatar
Default Re: Evo Magazine (Yaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yaz &raquo;</TD></TR><TR><TD CLASS="quote">
so the R came in 6th?</TD></TR></TABLE>
Reverse order.
Old Oct 3, 2006 | 08:54 AM
Rene M's Avatar
Default Re: (T3k C)
How do i get a copy to the states??
Old Oct 3, 2006 | 08:56 AM
Chris N's Avatar
Default Re: (Rene M)
Go to borders or barnes and noble.
Although at this point the next issue may be on the shelves there... im not really sure (although i should go buy one).
Old Oct 3, 2006 | 09:28 AM
NorthernXposure's Avatar
Default Re: (Chris N)
i got chills reading that... the type r will always have a home in my stable
Old Oct 3, 2006 | 05:14 PM
Madspeed's Avatar
great article...
Old Oct 3, 2006 | 05:24 PM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">How do i get a copy to the states??</TD></TR></TABLE>
It should be on the stands right now. Boarders should have it, the cover is different for the US printed issue. The US printed issue has a cover shot of a Lambo and a Ferrari F430 with the FWD shoot out on the bottom of the cover.
Old Oct 3, 2006 | 08:51 PM
vivid 02's Avatar
Default Re: (Haleiwa-Brando)
I bought the magazine last week. They had like 6 of them on the shelf.
Old Oct 3, 2006 | 08:59 PM
Speed Infliction's Avatar
Default Re: (vivid 02)
I can't believe nothing on the CTR!
Old Oct 3, 2006 | 09:23 PM
MGAGE's Avatar
Missed it at Borders... Already got the Oct. mags out!
Backorder up...!
Old Oct 4, 2006 | 12:02 AM
White98LS's Avatar
Default Re: (Speed Infliction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Infliction &raquo;</TD></TR><TR><TD CLASS="quote">I can't believe nothing on the CTR!</TD></TR></TABLE>
They didn't have the CTR in the UK.
Old Oct 4, 2006 | 03:09 AM
Bart-EK's Avatar
the UK did have the 2001+ CTR
Old Oct 4, 2006 | 05:15 AM
Edwin's Avatar
As someone had mentioned in a previous thread this magazine has a different cover in North America.
Has some gray Lambo and red Ferarri convertible on the cover.
This is definately a magazine to have for this FWD article.
Old Oct 4, 2006 | 09:22 AM
White98LS's Avatar
Default Re: (Bart-EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bart-EK &raquo;</TD></TR><TR><TD CLASS="quote">the UK did have the 2001+ CTR</TD></TR></TABLE>
Doh, forgot about that one, my bad. Ah well, struts...
Old Oct 4, 2006 | 09:40 AM
Todd00's Avatar
I said I don't want a title!
Default Re: (White98LS)
Doh, forgot about that one, my bad. Ah well, struts... </TD></TR></TABLE>
Most of the cars in the comparo have struts...but the other OEMs just figured out how to make them handle decently. Honda had a problem with that.
Old Oct 4, 2006 | 10:04 AM
98R-1144's Avatar
Doh.. my local Borders has the new issue out already too... any idea how to get a backorder of that issue?
