Whats the Best ecu to run on b16a2?
Old Oct 2, 2006 | 11:53 PM
drumminforev's Avatar
Default Whats the Best ecu to run on b16a2?
Right now im obd1 JDM p30 ecu.
Is it better to run the USDM or JDM p30.
Which ecu runs BEST on this motor. (for obd 1)
Is it worth it to upgrade back to odb2.
Old Oct 2, 2006 | 11:56 PM
BlueIntegraBoy's Avatar
Default Re: Whats the Best ecu to run on b16a2? (drumminforev)
I take it that it's actually a B16A2, if so, then the best ECU to run is a USDM P30. Keep it OBD1.
Old Oct 3, 2006 | 12:33 AM
Yes, its a b16a2 like the subject says. 2000 si us spec.
Why keep it obd 1....
and Since i have a jdm ecu, am i seeing any perfomance/gas milage loss because of it?
Old Oct 3, 2006 | 08:47 AM
bump for best ecu to run
Old Oct 3, 2006 | 09:01 AM
Luserkid's Avatar
You already got the answer run the USDM P30 ecu from the Del Sol. Really though you wont notice a difference in anything between the US and JDM ecu. If you want to go back to obd2 then do it, it doesnt matter as its all the same map.
Old Oct 3, 2006 | 09:09 AM
Default Re: Whats the Best ecu to run on b16a2? (Luserkid)
ok..sweet
Old Oct 3, 2006 | 01:51 PM
forcefedferio's Avatar
i got a p28 chipped runnin a crome program on an all motor setup...its pretty ****...just my .02
Old Oct 3, 2006 | 02:07 PM
cambopheonix56's Avatar
Default Re: Whats the Best ecu to run on b16a2? (1jdmferio)
Keep it obd1 so you can tune down the road if need be
markcat
Engine Management and Tuning
Sep 30, 2008 10:24 AM
Jonovision
Aug 4, 2008 02:29 PM
r1ynb
Jan 8, 2007 07:08 AM
da_rimrocka
Jan 25, 2006 03:48 AM
totaled
32
Aug 17, 2003 09:30 AM
