Distributor Caps: USDM b16a2 = JDM b16a2?
Old Oct 2, 2006 | 11:10 PM
fridexter's Avatar
Default Distributor Caps: USDM b16a2 = JDM 2nd gen b16a?
Old Oct 3, 2006 | 01:45 AM
Timmay's Avatar
Default Re: Distributor Caps: USDM b16a2 = JDM 2nd gen b16a? (fridexter)
US and JDM b16s have the same size distributor.. check the part # of the one he got you and look up what it fits
Old Oct 3, 2006 | 11:04 AM
philosofy1's Avatar
Default Re: Distributor Caps: USDM b16a2 = JDM 2nd gen b16a? (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">US and JDM b16s have the same size distributor.. check the part # of the one he got you and look up what it fits</TD></TR></TABLE>
correct me if i'm wrong, but i thought all b-series are the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fridexter &raquo;</TD></TR><TR><TD CLASS="quote">Bump for additional input! </TD></TR></TABLE>
but i definately know for sure though the usdm b16 will work.
Old Oct 3, 2006 | 11:13 AM
Timmay's Avatar
Default Re: Distributor Caps: USDM b16a2 = JDM 2nd gen b16a? (philosofy1)
i dont think LS uses the same as the Vtec models..
Old Oct 3, 2006 | 12:41 PM
carlosd68's Avatar
i had this same problem,,i had a jdm b16 and the usdm b16 distributer cover wouldn't fit.....i tried the integra type r and it fit perfectly!
Old Oct 4, 2006 | 12:26 PM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">correct me if i'm wrong, but i thought all b-series are the same?</TD></TR></TABLE>
Sure thing. The GSR and ITR's take a P72 cap which will not line up if you have the P54/PT2 cap. I found out the hard way. Apparently someone put the "other" distributor on the wrecked '97 GSR donor car because the P72 cap I ordered did not line up. Got a P54/PT2 cap and worked perfectly.
Old Oct 10, 2006 | 04:01 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (fridexter)
The PT2 cap is the OBD1 cap and will work on just about any OBD 1 D-Series or B16A or B18A/B
The P54 cap is the OBD2 cap and will work on just about any OBD 2 D-Series or B16A or B18B
The P72 cap will work for all B18C1/5
Old Oct 10, 2006 | 09:46 AM
blaze the chemi's Avatar
There's a set of number/letters to the right of the cap on the metal part of the distributor next to the bolts to the head. You can look it up on the web to see where the distributor came from.
Old Oct 10, 2006 | 01:01 PM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fridexter &raquo;</TD></TR><TR><TD CLASS="quote">Ah, so there's 3 types of caps available for b-series. Is there any way to check what type of distributor and cap I'll need, based on any markings on the distributor itself? i.e, some way that won't involve me cracking the cap off</TD></TR></TABLE>
Well if you bought one for a B16A2, you bought a P54. I would try the PT2, as I doubt the P72 would work.
I have no knowledge if the JDM distributors are different or not.
Old Oct 10, 2006 | 01:15 PM
drumminforev's Avatar
Default Re: (Mr Hammond)
My b16a2 distributor will not fit autozone distributor caps either. The one on it before i replaced it fit perfect, how do i know which to buy and where can i buy it?
Old Oct 11, 2006 | 04:45 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (drumminforev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev &raquo;</TD></TR><TR><TD CLASS="quote">My b16a2 distributor</TD></TR></TABLE>
Well if you have a B16A2 distributor, why didn't you buy a B16A2 distributor cap?
diviznrider
Aug 22, 2011 06:29 PM
ketchup
Apr 8, 2008 08:16 PM
S1_DJai
Oct 30, 2005 11:05 PM
dicklee
Mar 10, 2004 08:27 PM
DumpedSi
Aug 27, 2003 03:27 AM
