2007 CR-V front brakes
Old Oct 2, 2006 | 09:33 PM
Evs-One's Avatar
Solbros Owns Me
Default 2007 CR-V front brakes
I'm going to look into this and see what fits/doesn't fit. 11.65" front, 12" rear...2 piston front calipers. Gonna see if I can warranty some and see if they'll fit the ITR hub and possibly fit under stock wheels. No point in this...unless someone knows if they fit or not!?
Old Oct 2, 2006 | 10:26 PM
BlueIntegraBoy's Avatar
Default Re: 2007 CR-V front brakes (Evs-One)
Are the new CR-Vs RWD? Unusual to have larger rear brakes on a FWD car, even yet as AWD.
Old Oct 3, 2006 | 12:11 AM
White98LS's Avatar
Default Re: 2007 CR-V front brakes (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Are the new CR-Vs RWD? Unusual to have larger rear brakes on a FWD car, even yet as AWD.</TD></TR></TABLE>
AWD as they have always been.
Old Oct 3, 2006 | 02:59 AM
88 rex's Avatar
Default Re: 2007 CR-V front brakes (White98LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White98LS &raquo;</TD></TR><TR><TD CLASS="quote">
AWD as they have always been.</TD></TR></TABLE>
Front biased AWD.
Old Oct 3, 2006 | 09:15 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: 2007 CR-V front brakes (88 rex)
Whether it's available or not, you do NOT want bigger rear brakes than front brakes.
Old Oct 3, 2006 | 10:01 AM
davidnyc's Avatar
Default Re: 2007 CR-V front brakes (Stinkycheezmonky)
The rear brakes are bigger diameter but they are probably not vented and therefore also rather thin rotors.
Therefore, yes they are bigger in diameter but not stronger rear brakes. This is typical, look at most 4 disc setup on SUV's, Pickups, etc. they have large diameter rear brakes, just thin and not vented.
Old Oct 3, 2006 | 10:21 AM
Suspetise...
Default Re: 2007 CR-V front brakes (davidnyc)
Vented or not, I'd imagine clamping on the outer edge of a larger diameter disc would increase braking power. I'm assuming the lack of vents is because the rears don't get as hot and thus don't need as much cooling. Am I mistaken?
Old Oct 3, 2006 | 11:16 AM
davidnyc's Avatar
actually, from what I remember, I think they are bigger in diameter for the clamping surface is still smaller....like a big ring or something... why? not sure.
Old Oct 3, 2006 | 11:42 AM
Big Phat R's Avatar
F*ck the CR-V brakes - get the new 2007 MDX brakes.
13" front
13.2" rear.
http://www.vtec.net/articles/v...07022
Old Oct 3, 2006 | 12:06 PM
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">actually, from what I remember, I think they are bigger in diameter for the clamping surface is still smaller....like a big ring or something... why? not sure.</TD></TR></TABLE>
Uh...huh. Weird. Maybe for looks or something goofy like that?
BRNCD7
Honda Fit
12
Jan 21, 2006 02:05 PM
tali
Nov 12, 2005 02:20 PM
popRAWvtec
Aug 26, 2005 12:43 PM
boost'dsiR
Jan 2, 2005 07:51 PM
SuicideSlide
Jul 13, 2004 10:14 AM
