Will 94-95 (integra style) civic driver side mount work on b20 swap?
Like title says my current driver side mount seems to be the same as integra mount which is needed to swap my b20 in. Will this mount work or should i go with integra mount?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gmoney16 »</TD></TR><TR><TD CLASS="quote">Like title says my current driver side mount seems to be the same as integra mount which is needed to swap my b20 in. Will this mount work or should i go with integra mount?</TD></TR></TABLE>
If you're asking if the 94-95 Integra mount will work with the B20, then the answer is yes.
yea i know the integra mount will work.. Ive got a d16z6 in my eg and it has the 94-95 driverside mount that came in eg's which resembles the integra driverside mount exactly from what i can tell. Just wondering if they are the same or if it wont work on the b20?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gmoney16 »</TD></TR><TR><TD CLASS="quote">yea i know the integra mount will work.. Ive got a d16z6 in my eg and it has the 94-95 driverside mount that came in eg's which resembles the integra driverside mount exactly from what i can tell. Just wondering if they are the same or if it wont work on the b20?</TD></TR></TABLE>
It should, you know you're one of the few people that have ever noticed the 94-95 Z6 mount is the same as the B-Series? I had a comparison of mounts and brackets up on my old website.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gmoney16 »</TD></TR><TR><TD CLASS="quote">Good stuff, so your sure they are the same? Sounds like i wont be buying an integra driver side mount then. thanks!</TD></TR></TABLE>
They're the same.
They're the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptran13 »</TD></TR><TR><TD CLASS="quote">
Few people? You would have to be retarded not to notice. Anyone that has ever seen a 3-bolt will know they are the same mount. Look up the part #, they are the same.
</TD></TR></TABLE>Few people? You would have to be retarded not to notice. Anyone that has ever seen a 3-bolt will know they are the same mount. Look up the part #, they are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeCiviC251 »</TD></TR><TR><TD CLASS="quote">yes but the bracket on the engine is not the same! make sure you a b18b or any besries engine bracket that bolts to the driver side mount</TD></TR></TABLE>
WTF. Of course they're not. B-series brackets have 3-bolts and the D-series have two bolts.
dutchman5
Feb 6, 2003 12:48 AM
