Honda S2000 Honda S2000
Car shut off on cold starts.
Old Oct 2, 2006 | 05:09 PM
revhi's Avatar
Default Car shut off on cold starts.
Background: Comptech s/c S 7 psi, Emanage.
5 days ago it was raining, I started my car and let it idle about 2 minutes and started backing up. Half way down the driveway, it stalled. I was not on the gas since the driveway is on an incline. I tried 5 times to start it and each time it would barely turn over and sputter than shut off again. On the 6th time I gave it a bit of gas and it seemed to stabilize and stay on. Went where I had to go no problems and came back no problems. Started fine each time after. I chalked it up to maybe the humidity.
3 days ago while leaving work, 70 degrees sunny all day. I started the car. Idled for about a minute. All of the sudden, the idle started going up and down a bit up to 2000 rpm and down to near stalling and sputtering. Again I gassed it a bit and it stabalized.
Yesterday, it stalled agian, but good thing is it through a CEL this time, P1259. My scanner says A/F metering issue, but I know most discriptions say VTEC malfunction. After the air pump kicks off, my a/f stays about 11.9-12.5 at idle for a few minutes before it reached 2 bars of temp. Thats when the car usually cuts off. I noticed while driving now, I let off the gas, it stays rich for a few seconds before slowly going back to lean. Still fine while cruising and if I get on it.
I cant get it to my tech until next week.
Old Oct 2, 2006 | 07:25 PM
Yobz's Avatar
5 days ago - I would have said that the water was draining directly on your CAI causing a hydrolock, but it looks like you have the Comptech intake box and not AEM v1.
3 days ago - I would suggest a MAP whack.
Yeah best to get the car checked.
Old Oct 6, 2006 | 04:04 PM
revhi's Avatar
bump, any other ideas?
Old Oct 9, 2006 | 10:01 AM
evil vapor's Avatar
Default Re: (revhi)
have you tried checking the wiring at the ecu to insure no shorts?
Nolenrob7
18
Apr 4, 2017 03:30 PM
dwkt
Mar 7, 2012 11:17 AM
jonoknut
Feb 24, 2009 09:07 PM
