04 ex 4dr maitnance light on.
searched came up with some but none of them seemd to be right and were for defferent years of cars but for a civic. where is the button for re-setting the maitnance light on a 04 4dr civic ex?
i read on other hondas its above the right leg when sitting in the driver seat under the dash. is that right and im just blind or did they move it on 04 civics?
i don't think there is a button for resetting the maint. light switch i think there is certain way you have to turn the agnition key and hold it there for some time to make the light go away.
i have a 01 civic and the method for mine is stated in the owners manual. check yours it probably is in there.
turn the car off
hold the button on the gauges
turn the key to the ON position on acc but ON
but do not start it
hold the button for about 10 seconds until the light blinks a few times than turns off...than let go of button and voila!
but do not start it
does the light always come on for a second before starting the car? i did ragingSPAM's way and it goes on now for about a second with the key in the on position(car not started) and then it turns off. that right? or should it not even flash on for a second before starting?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-rome »</TD></TR><TR><TD CLASS="quote">does the light always come on for a second before starting the car? i did ragingSPAM's way and it goes on now for about a second with the key in the on position(car not started) and then it turns off. that right? or should it not even flash on for a second before starting?</TD></TR></TABLE> yes that is correct. the maint. light should go on for a few seconds during the bulb check phase after turning the key to the ON position
signals34
Jun 24, 2005 06:32 PM
JDMvtecDRAGSTA
Sep 12, 2004 03:45 PM
