BFG. drag radials on stock axles....
I have a Em1 with somewhere around 210-115whp ls/vtec... I kind of wanna get the BFG. drag radials 225/50/15 (track use only) to get the most out of the car but i wanna know how safe it is to run them on stock axles???
Also how good are the Azenis 205/50/15???
I live about 1 hour away from the track and its my daily driver
Azenis are good for daily driving and auto cross but aren't a really good drag tire at all due to the stiff sidewall. I have them on my car and the best Ican get my 60fts down to is 2.1 seconds. Im still trying to decide if I should get some bfg drag radials or go with some slicks.
great info... I just went to the track last weekend and some people were saying that BFG. pop stock axles... I think until certain amount of power they will be fine with stock axles..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAlover »</TD></TR><TR><TD CLASS="quote">great info... I just went to the track last weekend and some people were saying that BFG. pop stock axles... I think until certain amount of power they will be fine with stock axles..
they can but it is mostly from wheel hop, I have only broken 2 stock axles on BFG's with way more power on tap
</TD></TR></TABLE>they can but it is mostly from wheel hop, I have only broken 2 stock axles on BFG's with way more power on tap
BFG's are good for the streets, for the track I would get slicks and if you do not go to tall you'll be fine. For your set MT 20x8x14 or 22x8x15 (22x8x13 MH) and youll be happy with the results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxhatched »</TD></TR><TR><TD CLASS="quote">BFG's are good for the streets, for the track I would get slicks and if you do not go to tall you'll be fine. For your set MT 20x8x14 or 22x8x15 (22x8x13 MH) and youll be happy with the results.</TD></TR></TABLE>
agreed.if they'll just be for track use,go ahead and get slicks.they'll help you much more than the radials.
as for axles,it all depends.you can break axles with a stock D15 and street tires if you try.preload the drivetrain,and avoid wheelhop,then you should be fine.i run 24.5" slicks with about 325HP on stock axles-never broken one.
Chris
Chris
thanks for the support... I kind of like to see cars running on radials for some reason slicks it's not my thing yet... i see slick more on a race car than on a DD.
