Buying used prelude. Need some help w/ compression test numbers
Old May 1, 2002 | 10:46 PM
95civic's Avatar
New User
Default Buying used prelude. Need some help w/ compression test numbers
I will probably be buying a 93 prelude vtec so I had a compression test done and it came out like this: 210, 206, 204, 198. I am not too familiar w/ engines but I was just wondering if those numbers are ok or not. When I called Honda they said as long as the cylinders were within 10 of each other the engine was probably still strong. Should I be concerned at all with the one that read 198? Thanks for any help.
Old May 1, 2002 | 10:55 PM
aeolus's Avatar
Default Re: Buying used prelude. Need some help w/ compression test numbers (95civic)
well,being that the numbers go down a bit on every cylinder consecutively,The engine may have been cold.But 210 is the base number to shoot for,You should get better readings when then engine is warm.Sounds good though if its a usdm motor.
Old May 2, 2002 | 05:10 AM
Finest's Avatar
When I called Honda they said as long as the cylinders were within 10 of each other the engine was probably still strong. Should I be concerned at all with the one that read 198?.
I think what they meant was +/-10%. So yes, cylinder 4 should be fine.
Vladglad
Oct 20, 2016 07:20 PM
Belarus
Apr 2, 2010 03:01 AM
professorman
May 2, 2007 01:02 PM
JSpekBB4
Feb 18, 2006 05:54 PM
7808
Mar 2, 2004 06:26 PM
