Help: Jun3 TUNING TIPS PLZ
can someone help me tune my Jun3s... fuel wise? I'd relaly love to hear some of the success you've had with fuel settings... by this I mean:
Did you use a vafc? hondata?
if so, tell me what your original ecu setup was, and how you altered it to make it work.
what size injectors?
what fuel pressure?
I realize this has been posted before, but I failed to find much of anything searching...
I'd really really appreciate the helping hand
what fuel pressure?
im using a chipped p28...
i have a vafc too but i only used it for my vtec engagement
i have stock injectors and my fuel pressure is on 40..
i havent dynoed my car yet but im expecting more...
vtec hauls *** wen u can take it up to 9000...
what vtec do you suggest, and I was thinking of taking out fuel up top and adding some down low... what do you think of that?
the big thing for tuning JUN III is the fuel and cam timing. I believe 0,0 is the recommended setting from JUN. My fuel pressure is at 50 psi at idle with the vacuum line on. Im running ctr pistons. Whats everbodies fuel set at and what ECU are you using. Also you peaked early for the JUN III cams. Ive usually seen them peak at the 8700-8800 rpm range
[Modified by RLukas, 8:42 PM 5/2/2002]
fuel settings?? lol
i sincerely hope you do not mean AFC settings.
RLukas: Im sure the stock intake and exhaust could have contributed to the
early peak. Also, NEVER quote pressure figures with vacuum
DYNO, every engine is different..SGT your right,stock intake and exhaust probably contributed to the early peak. But those are damned good numbers for no intake and exhaust. You tuned it right? Hondata for me soon
I mean, where did you add fuel and where did you take it out? Im trying to find a general trend with these cams in relation to certain ecus.
0,0 cam settings is good (But make sure it is really 0,0)
[Modified by t, 5:32 PM 5/2/2002]
...on a related note: Whenever the subject of JUN 3s comes up someone says "JUN ECU". Has anyone cracked this program to use as a starting point for Hondata?
Eh?
Eh?
