anybody know where can i buy honda ecu connectors
Old Oct 2, 2006 | 02:11 AM
RACEPAK's Avatar
Default anybody know where can i buy honda ecu connectors
hello everyone.
anybody know where can i buy honda ecu male\female connectors?
or. is anyody know the name of the manufacture?
thanks
Old Oct 2, 2006 | 08:01 AM
splitime's Avatar
Default Re: anybody know where can i buy honda ecu connectors (RACEPAK)
http://www.boomslang.us should have them.
Old Oct 2, 2006 | 08:52 AM
tepid1's Avatar
You mean pins and sockets or actual gray plastic pieces?
Old Oct 2, 2006 | 08:54 AM
RACEPAK's Avatar
Default Re: anybody know where can i buy honda ecu connectors (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">You mean pins and sockets or actual gray plastic pieces?</TD></TR></TABLE>
pins and actual gray plastic pieces
Old Oct 2, 2006 | 10:00 AM
Howitt's Avatar
this is a smartass remark but you can purchase them @ Honda or Acura Unless your trying to get them in bulk and cheaper
Old Oct 2, 2006 | 10:55 AM
RACEPAK's Avatar
Default Re: anybody know where can i buy honda ecu connectors (Howitt)
i need the ecu side (female for a OBD2 P3Y EURO ECU) i dont think honda will carry them....
Old Oct 2, 2006 | 11:05 AM
tepid1's Avatar
Did you try Hondata?
Old Oct 2, 2006 | 04:41 PM
TeamNextGenChris's Avatar
Tyco makes the exact same parts(or may even make them for Honda.not sure).a friend got them to send him a couple samples for an OBDI harness.i think they had a really high minimum order though.
Chris
Old Oct 2, 2006 | 04:46 PM
splitime's Avatar
Default Re: anybody know where can i buy honda ecu connectors (TeamNextGenChris)
Boomslang sells them!
I just bought an obd1 plug set last month
Old Oct 2, 2006 | 04:47 PM
Race Egr's Avatar
Default Re: anybody know where can i buy honda ecu connectors (splitime)
you can get them from aem to. Check there website out
Old Oct 2, 2006 | 08:40 PM
TurboLSVtecTeg's Avatar
Default Re: anybody know where can i buy honda ecu connectors (NAPIER)
AMP a subcompany of tyco electronics makes the ecu plug/pins and ecu pin interfaces. The only problem is that you will easily spend $3-4K on parts because of the extremely high minium order for the parts. The best place to get them is somewhere like HorsepowerFreaks who sells the AEM connector kits. Check AEM's website for the exact part numbers.
Old Oct 3, 2006 | 03:34 PM
wHOAlly's Avatar
Default Re: anybody know where can i buy honda ecu connectors (TurboLSVtecTeg)
http://www.aempower.com/ViewCa...ID=84
35-2611 = OBD 1
35-2610 = OBD 2
Old Oct 3, 2006 | 03:52 PM
HondaPartsHero's Avatar
Technical Hero
I've got some OBD1 or OBD0
Master23
Sep 30, 2005 03:27 PM
type r 01-1063
Nov 4, 2003 01:34 PM
