Need help! NSX calipers on 5-lug!
Old Oct 1, 2006 | 09:16 PM
uLTrAvTEc757's Avatar
Default Need help! NSX calipers on ITR 5-lug!
Ok. So over the weekend, I took my ITR 5 lug off of my Integra and put it on my EK hatch. I decided to put some used NSX calipers on the front while everything was apart. I used some new Legend rotors and pads on the fronts as well as a 99-00 Si proportioning valve. Everything looked fine, granted it was already 1130 at night and really dark when I finished. I checked over everything and went to park the hatch in front of my house. I only drove it for about 75 yards and heard some serious screeching and grinding. I parked it and checked the rears. They were ok. Checked the front and there are dug in gashes all teh way around the brand new rotors. They are the same on both sides. Everything seemed to be ok and in order when it went together. I did a search but could not figure out which information is right because there are different people saying different things. Do I need to use some parts off of the ITR calipers? Should I have used the ITR rotors? Any insight would be greatly appreciated. I really don't want to put the ITR calipers and rotors back on unless I have to. Thanks!
Modified by uLTrAvTEc757 at 9:26 AM 10/2/2006
Old Oct 1, 2006 | 09:22 PM
Naruto's Avatar
Default Re: Need help! NSX calipers on ITR 5-lug! (uLTrAvTEc757)
sounds like you have clearance issues. The same thing happened to me on my teg when I did the 5 lug conversion. I used prelude calipers. You may want to take it apart and double check everything again. Making sure that when you have it up on jack stands to rotate the rotor to see if it is indeed a clearance issue between your caliper and rotors.
Old Oct 1, 2006 | 10:08 PM
waddy41's Avatar
i got nsx calipers on my 5 lug...
what wheels are u running?
Old Oct 2, 2006 | 03:51 AM
Default Re: (waddy41)
I'm running 16 inch TE37's. The wheels are fine though. They are clearing everything ok. It's something to do with this combo. or i'm missing something. Help!
Old Oct 2, 2006 | 05:03 AM
citrus3000psi's Avatar
First...Look to see what is making contact on the rotor. Where ever this is it needs to be moved. Figure out how to move aka a spacer etc. Then move it.
Old Oct 2, 2006 | 06:27 AM
Default Re: (citrus3000psi)
I'm going to check today when I get off of work. I might end up just putting the ITR ones back on though.
Old Oct 2, 2006 | 12:21 PM
Default Re: (uLTrAvTEc757)
It's the outside top part of the caliper that is hitting. It's striking the rotor!
Old Oct 2, 2006 | 12:57 PM
walker111's Avatar
Is your axle nut tight?
Old Oct 2, 2006 | 04:21 PM
Rtistik.'s Avatar
Default Re: (walker111)
you used the ITR caliper brackets right?
Old Oct 2, 2006 | 06:46 PM
Kengs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uLTrAvTEc757 &raquo;</TD></TR><TR><TD CLASS="quote">It's the outside top part of the caliper that is hitting. It's striking the rotor!</TD></TR></TABLE>
Try taking out the center brake pad retaining clip
Old Oct 2, 2006 | 07:58 PM
Default Re: (Kengs)
I used the complete NSX caliper assembly. Is this wrong? Should I have used the ITR part that mounts to up against the spindle?
Old Oct 4, 2006 | 06:57 AM
Was I supposed to use the ITR caliper brackets with the NSX calipers? Which pads should I use? NSX or ITR? Thanks!
Old Oct 4, 2006 | 07:08 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uLTrAvTEc757 &raquo;</TD></TR><TR><TD CLASS="quote">Which pads should I use? NSX or ITR?</TD></TR></TABLE>
It doesn't matter. NSX front pads and ITR front pads are the same size and shape, and can be interchanged without problems. When you order aftermarket front pads, you will find that they sell the same part number for either car.
It makes it easy for some of us to keep track of our parts for multiple cars...
Old Oct 4, 2006 | 09:55 AM
waddy41's Avatar
thats weird i had usdm itrs on before..and now im running 15" work wheels
Old Oct 4, 2006 | 10:28 AM
-Infinity-'s Avatar
I will also be doing this mod in the next month or Two. Im using this thread as a reference. https://honda-tech.com/zerothread?id=239844
Old Oct 4, 2006 | 03:31 PM
Default Re: Need help! NSX calipers on ITR 5-lug! (-Infinity-)
Ok. So today, I went and got some new Legend GS rotors. I told them I need some front rotors for a 94' Legend GS coupe. I switched my caliper brackets. So, now I'm running, ITR caliper brackets, NSX calipers, and 94' Legend GS coupe rotors. One thing I did notice is that the rotors that they gave me this time seem to be the same thickness as my ITR ones. Should they be the thicker ones like the ones I messed up the first time? My brake pedal seems soft. Is this because the calipers are over-extending the pistons to hit the thinner rotors or is it because my booster, or master cylinder is bad? It stops so-so but you almost have to bury the pedal to the floor. I bled the system 3 times all the way around so I don' think there is air in there. Any info. would be appreciated. Thanks!
Old Oct 4, 2006 | 04:02 PM
SuperTwinz's Avatar
You have NA1 or NA2 calipers?
Old Oct 4, 2006 | 07:52 PM
MiraiZ's Avatar
Default Re: Need help! NSX calipers on ITR 5-lug! (ThooperTwinz)
NA2 calipers will not fit the standard Legend/ITR rotors. They are 288mm and you need 300mm ones to accomodate the taller offset on the NA2's. I believe (although untested) rotors from a Accord Euro R (Acura TSX) or from an Oddyssey (RA9 ) will work if you are trying to an NA2 caliper upgrade
Old Oct 5, 2006 | 05:18 AM
an2ny888's Avatar
Default Re: Need help! NSX calipers on ITR 5-lug! (MiraiZ)
RA9 rotors will need to have the hub hole enlarged in order to fit the itr hub
Old Oct 5, 2006 | 05:53 AM
Default Re: Need help! NSX calipers on ITR 5-lug! (an2ny888)
My NSX calipers came off of a 92 or 93.
Old Oct 5, 2006 | 07:56 AM
JDMTurboEG6's Avatar
i did the same swap on my buddys itr. just use your stock itr rotors and theyll bolt up like stock.
Old Oct 5, 2006 | 10:39 AM
Default Re: Need help! NSX calipers on ITR 5-lug! (JDMTurboEG6)
JDMTurboEG6 - Yeah, that's basically what I did. I was just wondering about the space in between the caliper and the rotor. It looks right to me, not too big or small of a gap. I just don't know why my brakes still feel so soft. They are engaging but not until the pedal is pressed in about 65% of the way. Anyone know how to tell if the master cylinder is bad?
Old Oct 5, 2006 | 10:45 AM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTurboEG6 &raquo;</TD></TR><TR><TD CLASS="quote">i did the same swap on my buddys itr. just use your stock itr rotors and theyll bolt up like stock.</TD></TR></TABLE>
That's dumb advice - the whole reason for the swap is to use the THICKER (26MM) rotors of the NSX/Legend for increased heat sink.
Modified by Big Phat R at 2:44 PM 10/5/2006
Old Oct 5, 2006 | 03:05 PM
Rtistik.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uLTrAvTEc757 &raquo;</TD></TR><TR><TD CLASS="quote">Ok. So today, I went and got some new Legend GS rotors. I told them I need some front rotors for a 94' Legend GS coupe. I switched my caliper brackets. So, now I'm running, ITR caliper brackets, NSX calipers, and 94' Legend GS coupe rotors. </TD></TR></TABLE>
did the squeaking noise go away? the setup you're running is the EXACT setup i, as well as the seller who sold me the calipers had..
sorry i can't answer your other question
Old Oct 5, 2006 | 03:16 PM
Kengs's Avatar
Default Re: Need help! NSX calipers on ITR 5-lug! (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">
The NSX/Legend GS rotors are actually 28mm thick - and you're exactly right about using the thicker rotors
