Building An LSVtec Turbo
Hey guys, i finally got my hands on a B18a and a B16a, so the saga begins.
My questions are:
What pistons do you guys recommend to go with a rebuilt b18a that has a shot peened and balanced rotating assy. including Eagle rods. Should i go with a lower compression piston? i plan on running 15+ Psi on this motor.
What type of head work is recommended for running that level of boost on my Vtec head? can anyone recommend what valve springs i should go with? if i am on a budget is it ok to run the stock cams? Also, what computer should i use with this lsvtec setup? i relise i will have to load a basemap and start from scratch with tuning on a dyno, but will my chipped PM6 be ok for the task?
My questions are:
havoc productions
Aug 25, 2003 11:17 AM
