eg corner light prob.. help please..
well first i searched on ht and didnt find anything about this, but for some reason on my 93 hatch, the front driver side corner light only works when i hit the blinker, when i turn on the day lights it doesnt light up.. the passenger side works fine with the blinker and with the day lights its just the drivers side giving me this prob.. i check all the connections and everything seems fine.. can someone help me to fix this?
- Sonny -
- Sonny -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madskilz407 »</TD></TR><TR><TD CLASS="quote">Well i know the bulb works because when i hit the blinker it turns on, just when i turn the day lights on nothing happens..
- Sonny -</TD></TR></TABLE>
i believe that there might be two diffrent filaments in that bulb, you may have burned one out but the other is fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">yea its a dual stage bulb.</TD></TR></TABLE>
1157
1157
Guest
Posts: n/a
I have the same issue, but reversed. My driverside corner light comes on with the running light, but when I hit the blinker it doesn't turn on. My passenger side works fine, so I switched the bulbs to see if it was the bulb and it still didn't work does anyone know how to fix this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EckoTech »</TD></TR><TR><TD CLASS="quote">I have the same issue, but reversed. My driverside corner light comes on with the running light, but when I hit the blinker it doesn't turn on. My passenger side works fine, so I switched the bulbs to see if it was the bulb and it still didn't work does anyone know how to fix this?</TD></TR></TABLE>
fuses? check the connection. make sure its getting power.
douglaslovin
Apr 6, 2009 04:50 PM
