just a simple alignment question
Old Oct 1, 2006 | 06:32 PM
G2_Fella's Avatar
Default just a simple alignment question
should i do alignment before or after i put my new wheels on?
plan to get it done the same day i lowered my car.
Modified by G2_Fella at 4:14 AM 10/2/2006
Old Oct 1, 2006 | 06:36 PM
ATEJ8FTW's Avatar
you should do an alignment after your lower and put new wheels on. it should be the last step.
Old Oct 1, 2006 | 06:37 PM
cisurfer1's Avatar
Default Re: just a simple alignment question (G2_Fella)
Do it after you put on your new wheels and lower your car...your readings will be way off if you don't get a camber kit.
Old Oct 1, 2006 | 06:40 PM
t0p_sh0tta's Avatar
Default Re: just a simple alignment question (cisurfer1)
Camber won't be way off. The added negative camber can actually make the car handle better.
The toe will be off, and it will eat your tires. Align ASAP.
Old Oct 1, 2006 | 06:42 PM
turnsignalandy's Avatar
Default Re: just a simple alignment question (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">Camber won't be way off. The added negative camber can actually make the car handle better.
The toe will be off, and it will eat your tires. Align ASAP.</TD></TR></TABLE>
The key word is CAN. Camber will make your car handke better but not within spec, and probably at around 3 degrees, whic will also eat your tires out. Leave camber at less then 1 degree
Old Oct 1, 2006 | 06:43 PM
EG2Driver's Avatar
toe kills, camber helps to a certain extent. Thats why a car handles better with lower suspension. Do alignment last.
Old Oct 1, 2006 | 07:24 PM
G2_Fella's Avatar
thanks guys,
very quick and simple.
EF_9
Apr 9, 2008 02:45 AM
SpeedMachine
Suspension & Brakes
12
Nov 19, 2005 01:17 PM
kay_animation
Nov 3, 2003 06:56 PM
WheAs MaI MojO
Oct 11, 2002 08:06 PM
jdmrealm
Nov 28, 2001 11:29 PM
