ITR Tranny: Top Speed of Each Gears...
Old May 1, 2002 | 08:44 PM
Hard2Find's Avatar
Default ITR Tranny: Top Speed of Each Gears...
anyone know what the top speed of 1st gear, second gear, etc.... (at REDLINE)
Old May 1, 2002 | 08:50 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: ITR Tranny: Top Speed of Each Gears... (Hard2Find)
By my speedometer taking it pretty deep into redline
1st 40mph
2nd 62mph
3rd 94mph
4th 124mph
5th past the 150mph mark at least
Old May 1, 2002 | 08:54 PM
SpeedRacer00-667's Avatar
Default Re: ITR Tranny: Top Speed of Each Gears... (ActiveAero)
5th will bump off the rev-limiter if you have enough road.
Old May 1, 2002 | 08:56 PM
SoCal ITR's Avatar
Default Re: ITR Tranny: Top Speed of Each Gears... (SpeedRacer00-667)
Only if you have enough power, stock R's won't do it. Also people, keep in mind that the stock speedo/tach are both off.
Old May 1, 2002 | 09:36 PM
spoon_ek9's Avatar
Default Re: ITR Tranny: Top Speed of Each Gears... (SoCal ITR)
very true, they are way off after 100 mph.
Old May 1, 2002 | 09:41 PM
underrated99si's Avatar
5th will bump off the rev-limiter if you have enough road. Only if you have enough power, stock R's won't do it. Also people, keep in mind that the stock speedo/tach are both off.
Why is that ?
Old May 1, 2002 | 11:39 PM
SoCal ITR's Avatar
Default Re: ITR Tranny: Top Speed of Each Gears... (underrated99si)
Why are they off? I dunno.
Old May 1, 2002 | 11:48 PM
J_Edwards's Avatar
They are calibrated to be most accurate at speeds that most people drive at. I would assume that the accuracy is different depending on where you live also. But here in the states...most people are going 80 or below...so they use mechanisms that are accurate at speeds revolving around standard driving. If you go beyond that...they lose accuracy quickly becuase the sensors weren't really designed to be accurate faster than 100 or so.
Old May 1, 2002 | 11:56 PM
Mike B's Avatar
Default Re: ITR Tranny: Top Speed of Each Gears... (mr. clockwork)
4.40 w/ B20
1st = 28
2nd = 54
3rd = 75-78
4th = 94
5th = 128
Old May 2, 2002 | 01:15 AM
Reid's Avatar
Global Moderator
Stock R's will do it.
Old May 2, 2002 | 01:22 AM
DutchITR1689's Avatar
Euro gearbox + Euro final drive: (=JDM)
1st: 60 km/h @8500 rpm
2nd: 90 km/h @8500
3rd: 130 km/h @ 8500
4th: 180 km/h @ 8500
5th: 240 km/h @ 8400 rpm
Old May 2, 2002 | 04:05 AM
itRgirl's Avatar
these are the newest #'s
1st, 40mph@86oo
2nd, 70mph @8600
3rd, 98mph@8600
4th, 120mph@8600
5th, 144-146mph@7500
all have increased but the only way it's been checked is by the chp who said the car was going over 140 back when the speedometer stopped at 140.
Old May 2, 2002 | 04:15 AM
Cosworth's Avatar
Default Re: ITR Tranny: Top Speed of Each Gears... (itRgirl)
Old May 2, 2002 | 08:54 PM
Default Re: ITR Tranny: Top Speed of Each Gears... (Cosworth)
i have a apex N1 exhaust and h&r race springs and i hit the rev limiter in 5th gear numerous times...those are my only mods to my car. it had been done by many other R's.
Old May 3, 2002 | 03:42 AM
pinota's Avatar
Top speed in 5º gear: 260 Km/h- 162 mph at 9200 rpm, 8643 rpm at the V-AFC.
Old May 3, 2002 | 12:36 PM
vtec2nr's Avatar
Default Re: ITR Tranny: Top Speed of Each Gears... (pinota)
I did out the math for a USDM ITR on 205/50R15 tires at 8500 RPM.
Gear / Top speed (MPH)
1 / 41.1
2 / 63.0
3 / 91.0
4 / 119.8
5 / 156.4
R / 40.6
[Modified by vtec2nr, 4:44 PM 5/3/2002]
Old May 3, 2002 | 12:40 PM
skafia's Avatar
25 Year Member
Default Re: ITR Tranny: Top Speed of Each Gears... (vtec2nr)
40.6 MPH in reverse? LOL
Old May 3, 2002 | 12:45 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Active Streak: 60 Days
Default Re: ITR Tranny: Top Speed of Each Gears... (skafia)
VTEC hits in reverse y0.
Rguy, who doesnt have the cajones to try 40MPH in VTEC backwards style. And wouldnt if he did.
LAO
Feb 28, 2008 01:20 PM
jahasiel
Feb 5, 2007 08:24 PM
jonas
Jun 6, 2002 11:51 AM
xtrafastcivic
Nov 21, 2001 09:54 PM
