Please help ! Someone know what is the voltage...
Old May 1, 2002 | 08:41 PM
DomGS-R's Avatar
Default Please help ! Someone know what is the voltage...
Someone know what is the voltage for the Throttle Position Sensor ( on the throttle body) for a 96up ITR?
I think it's .48 volt for a GSR, is this right?
dont know for a ITR
Old May 1, 2002 | 10:36 PM
C-speed's Avatar
Default Re: Please help ! Someone know what is the voltage... (DomGS-R)
.45 (idle) to 4.5v (WOT)
Old May 2, 2002 | 08:23 AM
DomGS-R's Avatar
Default Re: Please help ! Someone know what is the voltage... (G3-TEG)
Thanks a lot for the information!!!
Here's my complete situation :
I have a 98 GSR with a Overbored TB to 63.5mm,
with the stock ECU the idle is perfect @750rpm
BUT when i put my 97 ITR ECU the idle is at 1100rpm!!!
Do you know why? is the TPS voltage the same on a ITR TB? vs a GSR TB?
Old May 2, 2002 | 08:32 AM
rainforest's Avatar
yes the voltage is teh exact on all b-series
Old May 2, 2002 | 08:35 AM
DomGS-R's Avatar
Default Re: Please help ! Someone know what is the voltage... (rainforest)
ok thanks! but do you know my idle is diffrent?
Old May 2, 2002 | 08:55 AM
rainforest's Avatar
you might have a problem with the ecu i have seen this happen before what year itr is it from. sounds like you are getting to a sensort to try to feed more fuel to the motor.
Haccord1996
Oct 31, 2011 03:05 AM
litoekneeil
Feb 26, 2011 07:55 PM
pinota
Dec 9, 2002 08:55 AM
SpoolnG2
Oct 17, 2002 06:51 PM
Eggman
Jan 28, 2002 11:08 AM
