Whats the top mph in each gear? Searched
Old Oct 1, 2006 | 03:05 PM
SiR99's Avatar
Default Whats the top mph in each gear? Searched
I new that 1st went up to around 40 mph so I thought
1st - 40mph
2nd- 80mph
3rd- 110mph
but when I tried,
1st - 40mph
2nd- 60mph
3rd- 90mph
Is this right?
Old Oct 1, 2006 | 03:32 PM
Chris F's Avatar
Default Re: Whats the top mph in each gear? Searched (SiR99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR99 &raquo;</TD></TR><TR><TD CLASS="quote">I new that 1st went up to around 40 mph so I thought
1st - 40mph
2nd- 80mph
3rd- 110mph
but when I tried,
1st - 40mph
2nd- 60mph
3rd- 90mph
Is this right?</TD></TR></TABLE>
yeah, approximately.
1st 3.230 / (8400 rpm) 39 mph
2nd 2.105 / (8400 rpm) 60 mph
3rd 1.458 / (8400 rpm) 87 mph
4th 1.107 / (8400 rpm) 115 mph
5th 0.848 / (8000 rpm) 143 mph
Old Oct 1, 2006 | 03:49 PM
SiR99's Avatar
ya, thats seems about right, just wanted to see if 1st went up higher then the other gears. thanks
Old Oct 1, 2006 | 04:00 PM
totsie7944's Avatar
yea its about right...but kinda depends on where your rev limiter is set...
Old Oct 1, 2006 | 04:04 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Whats the top mph in each gear? Searched (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">yeah, approximately.
5th 0.848 / (8000 rpm) 143 mph</TD></TR></TABLE>
The numbers are 40.3, 61.9, 89.3, 117.6, and 153.6 at 8400 RPM, according to the gear ratio spreadsheet. I don't know if the differences are due to rounding or what (other than in fifth, which is at redline and may not be achievable due to aerodynamic drag)...
Old Oct 1, 2006 | 04:16 PM
totsie7944's Avatar
Default Re: Whats the top mph in each gear? Searched (nsxtasy)
just wondering....at 9500 rpms whats the speed? I am not sure how your calculating this numbers....and waaaay too lazy and tired to figure it out haha
Old Oct 1, 2006 | 05:35 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Whats the top mph in each gear? Searched (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">just wondering....at 9500 rpms whats the speed? I am not sure how your calculating this numbers....and waaaay too lazy and tired to figure it out haha</TD></TR></TABLE>
Math challenged, huh?
Take each number above, divide by 8400 and then multiply by 9500 and you'll get your answer.
Old Oct 1, 2006 | 05:37 PM
Ford Prefect's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Math challenged, huh?
Take each number above, divide by 8400 and then multiply by 9500 and you'll get your answer.</TD></TR></TABLE>
Sheesh, what DO they teach kids these days?
Old Oct 1, 2006 | 07:09 PM
Chris F's Avatar
I can't open the spreadsheet (through no fault of the spreadsheet), but:
Was it calculated to fuel cutoff or 8400 redline? And, did it take into account the actual diameter of the OEM tires (versus the theoretical height of a 195/55 R15 tire)?
I think those numbers are from the owners manual, and may have been converted from km/h, but they seem consistently different.
Old Oct 2, 2006 | 12:15 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">I can't open the spreadsheet (through no fault of the spreadsheet), but:
Was it calculated to fuel cutoff or 8400 redline? And, did it take into account the actual diameter of the OEM tires (versus the theoretical height of a 195/55 R15 tire)?</TD></TR></TABLE>
The spreadsheet gives speeds for RPM readings at 100 RPM intervals, all the way up to 9500 RPM. The figures I quoted are for 8400 RPM.
The spreadsheet uses an outer diameter of 22.8 inches for the tires. I'm not sure where that number comes from. If you calculate the diameter of a 195/55-15 tire, it comes out 23.44 inches. The actual diameter that should be used in RPM vs speed calculations should reduce the diameter to account for the deflection of the tire by the pavement, but I'm not sure how much that would be, or whether that accounts for their 22.8 figure.
killerB16A
Aug 3, 2006 10:57 PM
EG type GTR
Jul 22, 2006 12:58 PM
Buitrex
18
Oct 13, 2004 08:57 PM
98prelude98
Sep 4, 2004 09:29 PM
TypeR01-424
Nov 18, 2001 08:33 AM
