Bad rings what caused this? Pics
Old Oct 1, 2006 | 02:50 PM
AndyD's Avatar
Default Bad rings what caused this? Pics
Hi all,
Check out sparkplug hold #2 from the cam gears:
http://www.we-todd-did-racing....x.jpg
I bought this swap off a local guy but when I went to change the valvecover gasket, I noticed this.
I am going to have a friend check the compression for me. I just wanted to know if bad rings are the only possibility.
Thanks
Old Oct 1, 2006 | 03:16 PM
Pilky's Avatar
Default Re: Bad rings what caused this? Pics (AndyD)
Subscribed
I did a tune up on my 95 the other day and 2 of the plugs had oil on it.
Old Oct 1, 2006 | 04:45 PM
hella_usdm's Avatar
looks like the plug was loose on that cylinder.
Old Oct 1, 2006 | 04:50 PM
AndyD's Avatar
Default Re: (hella_usdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hella_usdm &raquo;</TD></TR><TR><TD CLASS="quote">looks like the plug was loose on that cylinder.</TD></TR></TABLE>
You are right. The plug was loose.
What does that mean though? Major damage to the engine?
I am not sure if all the oil over the engine/valve cover was caused by it. Do you think so?
Qveon's Avatar
Wait what prelude engine has a chain drive cams?
Old Oct 1, 2006 | 04:54 PM
AndyD's Avatar
Default Re: (Qveon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qveon &raquo;</TD></TR><TR><TD CLASS="quote">Wait what prelude engine has a chain drive cams?</TD></TR></TABLE>
The limited edition H22 redtop.
Since this issue isn't engine specific, I figured I would try to see what you guys think.
Old Oct 1, 2006 | 05:11 PM
shutta's Avatar
what car is that motor from? doesn't look like an h22 to me for some reason.. what's the motor code?
Old Oct 1, 2006 | 05:19 PM
hella_usdm's Avatar
Default Re: (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">
I am not sure if all the oil over the engine/valve cover was caused by it. Do you think so?</TD></TR></TABLE>
The oil was most likely from something else. If you had that much oil in the cylinders your motor would be fubared' I had this happen to me once and there was no damage as a result.
Old Oct 1, 2006 | 05:39 PM
mgags7's Avatar
Default Re: (shutta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta &raquo;</TD></TR><TR><TD CLASS="quote">what car is that motor from? doesn't look like an h22 to me for some reason.. what's the motor code?</TD></TR></TABLE>
looks like an sr to me....
the plug being loose probably just filled that spark plug hole with soot....i doubt that it did any real damage inside
get that compression test done, if its bad, do a leakdown test and let us know how it comes out
Old Oct 1, 2006 | 05:51 PM
Attaus's Avatar
Considering the TB is facing the pullies, im 99.999% sure that's not any Honda motor.
Old Oct 1, 2006 | 05:58 PM
SteveoBA8's Avatar
Default Re: (Attaus)
sr20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">
get that compression test done, if its bad, do a leakdown test and let us know how it comes out</TD></TR></TABLE> i agree
Old Oct 1, 2006 | 06:45 PM
AndyD's Avatar
Default Re: (SteveoBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">sr20</TD></TR></TABLE>
I just wanted to check. I didn't want to swap it in only to find out the cylinder is bad.
I'll do a compression test on it and see.
Thanks for the help, guys!! That's why i posted here.
Old Oct 2, 2006 | 03:49 AM
PirateMcFred's Avatar
Default Re: (AndyD)
Unless there are major problems with that one cylinder then the oil probably came from somewhere else like the valve cover gasket. The only real issues with running a loose spark plug generally long term. If the electrical ground for the spark was in the threads instead of the gap, then it can errode the threads making them weaker. Another issue is the possitive pressure/negative pressure effect on the loose plug can have it rattle back and forth and ruin threads that way too. If you have a factory torque spec I would torque it a few times in succession to make sure that it is not stripped.
Pirate
Old Oct 2, 2006 | 07:21 AM
AndyD's Avatar
Default Re: (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">If the electrical ground for the spark was in the threads instead of the gap, then it can errode the threads making them weaker. Another issue is the possitive pressure/negative pressure effect on the loose plug can have it rattle back and forth and ruin threads that way too. If you have a factory torque spec I would torque it a few times in succession to make sure that it is not stripped.
Pirate</TD></TR></TABLE>
That's the first thing I thought when I noticed the plug was loose. I have heard of stories there the spark plug shoots out and tears off the threads in the head.
The substance over the coilpack/in the spark plug chamber is not oil. It is more of a grimey soot substance, like you all mentioned.
I'll clean it up as well as I can and put it all back together. I hope it is ok. If not, it won't be TOOOO big of a deal. The guy gave me a great deal on it.
Thanks for the help, all.
Oh, here are pics of what the engine looked like when I got it. I was just about to start cleaning it:
See all the oil/grime around the intake ports? It's all cleaned up now though.
Old Oct 2, 2006 | 10:14 AM
mgags7's Avatar
well it was still firing, so it was most likely just burning oil onto that metal, im sure the loose plug was leaking combustion at least slightly into that spark plug "hole"
Old Oct 2, 2006 | 05:01 PM
Default Re: (AndyD)
Ew a Fram filter...
Old Oct 2, 2006 | 05:36 PM
98TypeSH's Avatar
Finally getting the 240 project underway eah ?
i ended up selling mine to my gf lol.
I still got **** tons of SR parts as mine is sitting in a giant box all tore down.
I concur with everyone else as well.. loose plug. If it were oil an old or messed up plug gasket would do the same type of thing.
umskittles
13
Aug 3, 2011 06:40 PM
mickiemagik
May 21, 2007 06:16 PM
cogluve
Apr 12, 2005 03:13 PM
Eggman
Mar 26, 2003 07:52 AM
Colin
Mar 12, 2003 12:52 PM
