911 d15b1 w/obd1 distributor swap
My stock distributor is blown and I only have a obd1 distributor. I have the wiring harness that came with the distributor also. I managed to make a quick link for the coil power and I am currently putting together the second main harness for the distributor.
The site I found some info on only tells me to match up one fat wire with the other fat wire (white, there is two white wires same diameter). Does anyone know which wire goes where or a link to a good how to?
So far ive clearified matching wires
DP wiring/ obd1 MPFI wiring
Orange/blue=Orange/blue
Orange=Orange
White/blue=White/blue
white=?
white=?
?=Blue/green
?=Blue/yellow
?=White/green
?=white
i can post pictures. Please help.
Orange=Orange
white=?
white=?
?=Blue/green
?=Blue/yellow
?=White/green
?=white
well after alot of reading i found that its not going to work out... doh. The DPFI distributor is completly diffrent internally than the MPFI distributor. I have a back up plan although. I have a MPFI from a HF crx and HF ECU, two spare MPFI harness Si/HF and resistor box. Why not convert to mpfi... HF.. here we come!
holy **** what a mix breed engine. I doubt this setup has ever been done before in a 90 STD.
D15B1 block/4Speed tranny
D16A6 Head W/3angle valve job
D16Z6 exhaust manifold
HF intake manifold and injectors
HF ECU
I have a Y8 intake manifold (also 2 sets of obd0 Si injectors, one Si intake manifold with all sensors) with all the sensors but I'm not sure if they will work with the HF ecu.
Modified by alex17 at 1:14 AM 10/2/2006
HF ECU
