vtec sol. ques.
Old Oct 1, 2006 | 01:27 PM
jdmEF8racer's Avatar
Default vtec sol. ques.
i neva really thought about it but is it possible to hook a better vtec solinoid up to a diff motor like puttin a b16 sol. on a d16???
Old Oct 1, 2006 | 01:33 PM
89 civic si's Avatar
Default Re: vtec sol. ques. (jdmEF8racer)
why is this a better solenoid, the solenoid on the z6 is fine it does it does the job
Old Oct 1, 2006 | 01:36 PM
yea its good but i was jus wonderin if you put like a b16 sol on it will vtec hit sooner or harder...jus curious...u no jus one of those stupid questions people ask
Old Oct 1, 2006 | 01:38 PM
Default Re: (jdmEF8racer)
you would need a vtec controller to make it kick in faster, usually without mods kicking vtec in at a lower rpm then stock will just cause the car to loose horsepower i wouldnt even mess with it unless i had a forced induction setup or better cams
Old Oct 1, 2006 | 02:56 PM
Kidnkorner's Avatar
Default Re: hOT bEEF iNJECTION.
LoL is this thread a joke? Why would you need it to "KICK" harder, Or "sooner?" Has the camshaft profile been altered in a way that would require a lower RPM engagement? Would It make More power engaging sooner? The solenoids purpose is to get the rocker arm assembly to lock and ride on the high RPM camshaft lobe. As long as it's performing that function there would be no purpose.
IBTL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si &raquo;</TD></TR><TR><TD CLASS="quote">you would need a vtec controller to make it kick in faster</TD></TR></TABLE> Faster? Do you mean sooner? I don't think a VTEC controller will increase the speed at which a VTEC solenoid performs its function.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si &raquo;</TD></TR><TR><TD CLASS="quote">.....just cause the car to loose horsepower</TD></TR></TABLE>
Did you mean lose?
Modified by Lynx Bus Type R at 2:16 AM 10/2/2006
Old Oct 1, 2006 | 03:23 PM
.Manny.'s Avatar
Touching My Member
Default Re: hOT bEEF iNJECTION. (Lynx Bus Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lynx Bus Type R &raquo;</TD></TR><TR><TD CLASS="quote">LoL is this thread a joke? Why would you need it to "KICK" harder, Or "sooner?" Has the camshaft profile been altered in a way that would require a lower RPM engagement? Would It make More power engaging sooner? The solenoids purpose is to get the rocker arm assembly to lock and ride on the high RPM camshaft lobe. As long as it's performing that function there would be no purpose.
IBTL</TD></TR></TABLE>
DING DING DING...good answer
salandrew09
Jul 7, 2009 05:11 AM
phill_howz
Jun 12, 2007 01:49 AM
ProjectTib
25
May 24, 2007 11:45 AM
01S2KGrey
Honda S2000
31
May 22, 2006 01:05 PM
delsolrmp
Nov 15, 2003 07:46 AM
