Pilot bearing and throw out bearing?
Cant find out where the pilot bearing goes....I think I know where the throw out bearing is on the shaft but can some one help me and tell me where the pilot bearing is located
install the pilot bearing from the backside of the flywheel.......the side that the clutch does not touch....you may need to "persuade" it a little......good luck......
yes it goes in the flywheel, also if you put the bearing in the freezer for a couple hours, it will go in easier because the metal has contracted due to the cold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">lube the bearing, lay the clutch down, get an impact socket and a 2lb. hammer and just tap it in</TD></TR></TABLE>
Or use the press
Or use the press
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">
Or use the press
LOL, we've got that same press.
socket and hammer+portable press
Or use the press
</TD></TR></TABLE>LOL, we've got that same press.
Or use the press
thats the same flywheel I got but I got every thing done tranny is back on...Now time to drop in the engine getting it prepped see how long that takes and if not to long might drop in today
Or use the press
</TD></TR></TABLE>thats the same flywheel I got but I got every thing done tranny is back on...Now time to drop in the engine getting it prepped see how long that takes and if not to long might drop in today
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 »</TD></TR><TR><TD CLASS="quote">
Did you buy it new, cause I'm curious if you had the same issues we had with it.
</TD></TR></TABLE>Did you buy it new, cause I'm curious if you had the same issues we had with it.
I just put the engine in the car but I dont know what kind of problems did you have? I dont have all the hoses to have it running yet or piping but will shortly
We had problems with the thread not being taped all the way, fidanza said it was a commin problem. But the other problem was, one dowl pin was totally machined wrong and would slip right out.
litterbox
14
Jul 20, 2005 11:33 AM
