Do I need this for braided line?
#10 is what im talking about i got all the fittings to use it but then i realized the one side of it is a different size then the other. so can i eliminate it? it looks like some kind of proportioning valve for the clutch line
Think about it. Proportioning valve. Like it gives out different "portions" to MORE that ONE line. It's not a proportioning valve.
It could be a restrictor valve. No honda's didn't have that.
It's just a connection joint, because it would be rather hard to put that line on if it was one piece.
Also since you got that pic from a parts website, you could have just looked at the description which would have read:
" 010 46939-SR3-A01 JOINT, CLUTCH PIPE "
