Pulsating sound coming from car, possibly brakes. Pads always squeak as well.
Old Oct 1, 2006 | 01:23 AM
LastGenLude's Avatar
Default Pulsating sound coming from car, possibly brakes. Pads always squeak as well.
I have a 98 base prelude and when I drive I can hear "wooo, wooo wooo" humming coming from outside the car. It varies with speed, possibly a wheel bearing? How would I go about discovering whether or not I truly have a bad wheel bearing? Nine years old, would it happen that soon?
If not, what else could it be?
My brakes squeak a good bit, the fronts have tons of life left on them and the rears maybe 30% left. i've taken all the pads (but the drivers rear) off and greased them and put them back on...but they still squeal. i honestly dont think its the pads at all and its something else...however if its not pads or the wear indicators what could it be? Its only sometimes and it usually happens when i'm applying 40-50% of the brake pedal down. Hard breaking it doesnt happen.
Old Oct 1, 2006 | 07:01 PM
yOnKiNaToR's Avatar
Default Re: Pulsating sound coming from car, possibly brakes. Pads always squeak as well. (LastGenLude)
sounds like a wheel bearing or more likely a badly worn tire. i have a badly worn tire (the tread pattern goes up and down like a wave). it's causing that "woo woo" sound at certain speeds.
Old Oct 2, 2006 | 09:45 AM
jardolei's Avatar
For the squeaking, its probably the brake pads. I have the same problem, still have the pads from when I bought my lude at the beginning of summer. Its damn annoying, but once they get warm its usually ok. I just brake hard so it doesn't happen. Wainting to finish them off to install new "good" ones
Old Oct 2, 2006 | 01:07 PM
preludeguy_92's Avatar
Default Re: Pulsating sound coming from car, possibly brakes. Pads always squeak as well. (jardolei)
If it is a wheel bearing, the noise will get louder or softer when going around curves. When you go around a curve and the weight of the car shifts to the drivers side and the noise almost goes away then it is your passenger wheel bearing. And vice versa.
Old Oct 3, 2006 | 12:14 AM
Driving tonight...doing about 45 MPH I heard nothing. Going around u-turns I hear no increase.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yOnKiNaToR &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a wheel bearing or more likely a badly worn tire. i have a badly worn tire (the tread pattern goes up and down like a wave). it's causing that "woo woo" sound at certain speeds.</TD></TR></TABLE>
tires are near new.
Alan2005
Aug 8, 2017 07:44 PM
mexinug
Jun 7, 2007 09:59 PM
potatostix
Oct 26, 2005 05:54 AM
BlueRocket
Jul 29, 2004 09:27 PM
RolioPolio
Jun 29, 2002 01:38 AM
