after a day at the DRAG STRIP
did you just change the coolant recently? any smoke from the exhaust? any oil floating in the radiator? if you have a coolant leak chances are you could smell it, it smells sweet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel »</TD></TR><TR><TD CLASS="quote">sounds like "the couple of passes" was going to the drag strip?
I caught that too.
And in that case the answer should be no.
I caught that too.
i dont notice any smoke coming from the exhaust. there is no oil in the radiator floating around. where should i start smelling for coolant?
where are the most common places for coolant leaks?
:edit: my engine temps is fine after the runs. i checked my coolant reserve tank and it was at the min level when it was fine last time i checked
DanInOttawa
Jun 28, 2013 02:03 AM
hybridb18
Aug 6, 2003 09:00 PM
