Steering wheel vibrates after swap HELP
Old May 1, 2002 | 07:14 PM
0gsR's Avatar
New User
Default Steering wheel vibrates after swap HELP
I never had problem with this sort with my stock VX engine. But after my swap my steering wheel vibrates. I used all Teg mounts and torqued every bolt to spec and then re-torque thereafter. Is this normal since the B18c1 engine is heavier?
Old May 1, 2002 | 07:27 PM
rainforest's Avatar
Default Re: Steering wheel vibrates after swap HELP (0gsR)
well it should fell a little sponger less play on the car. so basiclly you might need to get a alingment also, so check it out.
Old May 1, 2002 | 10:03 PM
riceboy's Avatar
Default Re: Steering wheel vibrates after swap HELP (rainforest)
make sure all the suspension bolts are tight and that the axles are not bad/improperly positioned
Old May 2, 2002 | 06:07 PM
Honda4CX-T's Avatar
This is normal, remember you are placing a heavier engine on your chassis and you are probably still using your old Steering rack (worn bushings). I've had that "light vibration" on steering wheel at idle (traffic light) after driving around for awhile.
I've noticed it only during dramatic weather patterns (Hot one day & real Cold on the next day and viceversa).
You can correct the problem by changing those specific bushings wich allow the "light" vibrations to travel through your steering column.
Unless of course if it's really "bad" then check more than your steering rack !!! (such as other suspension components)
Old May 2, 2002 | 06:36 PM
It's James's Avatar
When you did the swap, did you take out the power steering? If so, then you'd defenitely feel a lot more vibrations in the steering wheel. Also check to see if its not the swap that causes the vibrations. From experience, i know that it could also be alignment, improper tire mounting/balancing, air bubble in tire(s), frozen/locked up brake calipers, or even a bent rim.
Old May 3, 2002 | 07:18 PM
hurleyburley's Avatar
When is it that your steering wheel vibrates? Moving? Not moving? RPMs? Speed? etc.
M-benz
Apr 22, 2012 07:56 PM
grandtheftlunchbox
Apr 20, 2011 07:02 AM
stwocams
Dec 1, 2002 11:31 AM
0gsR
May 2, 2002 02:29 AM
