Steering wheel vibrates after swap HELP
Old May 1, 2002 | 07:13 PM
0gsR's Avatar
New User
Default Steering wheel vibrates after swap HELP
I know this should be posted in Hybrid or Tech but need help.
I never had problem with this sort with my stock VX engine. But after my swap my steering wheel vibrates. I used all Teg mounts and torqued every bolt to spec and then re-torque thereafter. Is this normal since the B18c1 engine is heavier?
Old May 1, 2002 | 07:40 PM
willyboyK20's Avatar
Default Re: Steering wheel vibrates after swap HELP (0gsR)
does it do it at a specific speed, or all the time?
Old May 1, 2002 | 07:44 PM
0gsR's Avatar
New User
only when the car is at a stop and idling. normal idle.
Old May 1, 2002 | 08:39 PM
GokuSSJ4's Avatar
just a simple ?? went they install the mounts , did they happen to have inserts already ? just asking
Old May 1, 2002 | 10:34 PM
GZR4DR's Avatar
Default Re: Steering wheel vibrates after swap HELP (Spoon1)
Its prob just the motor needs a tune-up. Do a valve adjustment and hopefully that will help out with the vibrations.
Old May 2, 2002 | 02:29 AM
stevecockrill's Avatar
Mine does too....I put in the ES inserts when I did the swap. Its right at warm idle with the fan on "1" (750rpm), and can be bad enough that I rest my knee against the wheel to "absorb" the vibration. It rattles my MDs in the glovebox. Annoying, but it doesn't do it all the time.
Steve
raverx3m
Mar 10, 2015 08:15 PM
Uljima
Apr 8, 2014 08:07 PM
alwaysoverkill
Dec 6, 2006 08:45 AM
0gsR
May 3, 2002 07:18 PM
