tranny overfill?
If you dripped out of the VSS hole, you over filled the trans. It need only like 2 quarts but refer to your manual. There is that over fill plug that is located near the drain plug if you have level amount questions
theres a fill hole on the firewall side of the tranny .. take out the bolt and let the extra fluid flow out and when it starts to barely come out .. put the bolt back in and your good to go ..
JASIYAH6
Mar 9, 2009 10:05 AM
its just easier with the funnel i have to use the vss.
