fuel pressure
Old Sep 30, 2006 | 01:46 PM
skata89's Avatar
Default fuel pressure
hey all. Ive been looking around on this all day and cant really find anything. I have one of the b&m pressure gauges and its reading at 40 psi. Is that too lean for the 96 jdm itr motor? and should i get a fpr to raise it back to the stock psi?
Modified by skata89 at 3:26 AM 10/1/2006
Old Oct 1, 2006 | 02:26 AM
skata89's Avatar
bump
Old Oct 1, 2006 | 07:24 AM
Black R's Avatar
25 Year Member
Default Re: fuel pressure (skata89)
iirc, the correct static base fuel pressure should be between 47-54psi.
BUT, you should measure this with the fpr vacuum line off or pinched.
When connected, the vacuum line will actually lower this to the 40-42 range on the gauge.
*edit* just checked the helms and this thread confirms what the correct psi should be:
https://honda-tech.com/zerothread?id=1713045
EFjoe91
Engine Management and Tuning
Jan 7, 2011 10:54 AM
Mr.EM1
Jan 6, 2005 11:17 AM
TakaIntegra
Jun 18, 2002 06:30 AM
