spark plug wires help
i have a 1994 4 cycl accord ex. i plan on just changing my spark plug wires. if i do this, do i need to also change my spark plug and the distributor cap? if any1 has any instructions how to install the spark plug and wires plz give me information
you don't need to change them if they are in good shape.
the wire just pop off, but don't mix up the wires with the firing order.
sparkplug, um.. you need a socket for the sparkplug, turn in counter clockwise to remove it, put some anti seize on the new sparkplug(and check the gap), hand tighten it and then use a torque wrench to tighten it to 13 lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chinolal »</TD></TR><TR><TD CLASS="quote">i have a 1994 4 cycl accord ex. i plan on just changing my spark plug wires. if i do this, do i need to also change my spark plug and the distributor cap? if any1 has any instructions how to install the spark plug and wires plz give me information</TD></TR></TABLE>
replace them 1 at a time..
use NGK ZFR5F-11 for plugs and Honda factory plug wires .
JDM_SOHC
Apr 30, 2007 02:24 PM
