Need Help on B16
Old May 1, 2002 | 06:07 PM
B20zvtecek's Avatar
Default Need Help on B16
I did a B16 swap into one my friends 89 hb. it starts fine but idles really poor. Im guessing it might be the timming , but what else could it be? vacuum?
any help would be appreciated
Old May 1, 2002 | 07:45 PM
Phatwhippin_CRX's Avatar
Default Re: Need Help on B16 (B20zvtecek)
chances are it's a vacuum line or a bad TPS. Is the ECU throwing any codes? If not, double check all your vacuum lines.....
I used to have a pic of the B16 vacuum diagram, but i can;t find it. Look up B16a Vacuum lines on a search engine, and I'm sure you'll find a Diagram. Also, did you "T" in the FPR to the Map sensor, into the back of the intake manifold? Theres a bucnh of small things that could be off......
stockcrx
66
Nov 27, 2009 04:25 PM
Pworld925
Nov 14, 2008 06:27 PM
jokr78
Dec 16, 2004 02:36 PM
coot_er
Aug 11, 2004 05:57 PM
EP3_05
Feb 25, 2002 07:35 AM
