Need help identifying a couple lines to a 1st gen b16
So my broher handed me over the keys to his crx si with a 1st generation jdm b16 intact and as i was trying to clean out the IACV because the rex has a surging idle after warm, i found a couple lines disconnected and have no clue where they go about...
This line comes from a cylinder labeled pcv on it, did some searching but couldnt find where it might go...
This one seems to be blocked off with a screw in it, is that ok? Coming from the MAP sensor?
And is this supposed to be grounded to something? It sits in the intake well by the passenger headlight
any help/information on what or where these things go is appreciated because im fairly new to the honda world, thanx in advance
Modified by Pworld925 at 1:26 PM 11/14/2008
Modified by Pworld925 at 1:28 PM 11/14/2008
Re: Need help identifying a couple lines to a 1st gen b16 (Pworld925)
both of the hoses look like they are for the purge system - kind of hard to see in the pictures - the red hose in the 1st picture - does it go to the charcoal canister? (round thing to the left in the picture) - if it is from the charcoal canister, it plugs into the nipple at the top center of the throttle body (looking from passenger side) - the black hose looks like it is coming from the purge cut-off solenoid on the firewall - is this correct? - the purge is the cylinder on the right in the 3rd picture - the MAP is just to the left of the purge solenoid - if that is where it comes from, it connects to any vacuum port on the intake manifold - if that is what they are, neither is needed for the car to run correctly - may be needed if you have to pass visual emissions - don't know about the wire - the ring connector on the end is not OEM - maybe it was a wire someone added to power something - what color is the wire?
Re: Need help identifying a couple lines to a 1st gen b16 (jlicrx)
thanx jlicrx, ive uploaded larger pics so the lines can be better identified
well I bet it you follow the wire, it will lead into the passneger foot area. Check and make sure that it isn't connected to anything and maybe you can yank on it
stockcrx
66
11-27-2009 04:25 PM
Dforce
10-13-2006 07:17 PM
