Retain clutch, new flywheel, quick question
Old Sep 30, 2006 | 06:10 AM
43!'s Avatar
43!
Default Retain clutch, new flywheel, quick question
The block and trans are stuck together, no bolts left. Any good place to pry them apart. Helms says pull the trans from the block, i can't get it to budge.
Modified by 43! at 10:42 AM 10/1/2006
Old Sep 30, 2006 | 06:29 AM
RTW DC2R's Avatar
not necessarily, you can "eyeball" it but it can be a bitch to get the tranny back on (as if it wasnt enough of a bitch already)
Old Sep 30, 2006 | 10:02 AM
43!'s Avatar
43!
Default Re: (RTW DC2R)
Ok, thanks.
Old Sep 30, 2006 | 10:45 AM
B2FiNiTY's Avatar
Default Re: (43!)
I highly recommend you just go rent a tool, totally worth it.
Old Sep 30, 2006 | 06:17 PM
43!'s Avatar
43!
Default Re: (B2FiNiTY)
I bought the universal kit from NAPA but this crap is taking me way longer then I thought.
Clutch tool, check
Trans jack, check
Pickle fork, check
Punch set, check
wallet low, check
Old Oct 1, 2006 | 09:43 AM
43!'s Avatar
43!
Default Re: (43!)
See above./
Old Oct 2, 2006 | 08:49 AM
43!'s Avatar
43!
Default Re: Retain clutch, new flywheel, quick question (43!)
I removed all the bolts/mounts from the trans to block but the trans won't pull away as described in Helms.
Do you need to pry it apart? Any tips. I'm currently stuck.
Old Oct 2, 2006 | 09:34 AM
walker111's Avatar
Check for any other bolts. Has it seperated at all? I have never seen a trans that wouldnt seperate...
Old Oct 2, 2006 | 10:21 AM
43!'s Avatar
43!
Default Re: Retain clutch, new flywheel, quick question (walker111)
Does the starter need to be removed? I removed all the bolts around it. I didn't see it mentioned in the Helms though my friend said it needs to go.
I swear I got everything but it won't crack away from the block.
Old Oct 2, 2006 | 01:01 PM
walker111's Avatar
Take the starter off, knucklehead
Old Oct 2, 2006 | 01:17 PM
EG6-DC2's Avatar
Did you get the bolts on the engine to tranny side out? or the engine to tranny brace and cover?
Old Oct 2, 2006 | 02:50 PM
BrOkEn_Dc2's Avatar
Default Re: Retain clutch, new flywheel, quick question (EG6-DC2)
take off starter then gently work around trans to slowly pry off. its a bitch i know, spent 87 hours installing my new clutch and flywheel and i def. didnt have the tools you got
Old Oct 2, 2006 | 08:36 PM
RPRacing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 43! &raquo;</TD></TR><TR><TD CLASS="quote">Does the starter need to be removed? I removed all the bolts around it. I didn't see it mentioned in the Helms though my friend said it needs to go.
I swear I got everything but it won't crack away from the block. </TD></TR></TABLE>
the bottom/back starter bolt goes through the starter, through the tranny case, and into the block. You need to remove this bolt. I usually remove the starter to save weight when i drop the trans anyways. and the hole makes a nice handhold
Old Oct 3, 2006 | 11:46 AM
43!'s Avatar
43!
Default Re: Retain clutch, new flywheel, quick question (RPRacing)
Thanks for the help. The long lower starter bolt has been holding me up since Saturday.
Old Oct 3, 2006 | 11:47 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 43! &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the help. The long lower starter bolt has been holding me up since Saturday. </TD></TR></TABLE>
Lol, now joo know Glad ya got it off!
Old Oct 3, 2006 | 12:31 PM
RTW DC2R's Avatar
lol
$Tweezy
Mar 10, 2010 08:34 PM
Ls91sI
Jul 14, 2005 01:35 AM
Aphelion
Jun 5, 2005 09:29 PM
THCk20eg
17
Jan 17, 2005 10:19 AM
MyBigNut
Aug 10, 2003 12:54 AM
