whats the correct way to check tranny fluid
Old Sep 29, 2006 | 11:19 PM
primemal's Avatar
Default whats the correct way to check tranny fluid
I in the morning as i was trying to check to see why my d4 was bliking checked it and it marked none it was dry but car had not been on.I later that day went to autozone and they told me the car had to be running its this true?
Old Sep 30, 2006 | 10:28 AM
02 accord's Avatar
Default Re: whats the correct way to check tranny fluid (primemal)
Read the manual. The engine has to be warmed up and not running. I think for all the other cars, you need to have the engine running, but for hondas, you don't.
Old Sep 30, 2006 | 08:38 PM
Honda-Master's Avatar
is it an AT or MANUAL tranny ?
Old Sep 30, 2006 | 09:56 PM
primemal's Avatar
Default Re: whats the correct way to check tranny fluid (Honda-Master)
at
Old Oct 1, 2006 | 12:01 AM
shadow_ridge's Avatar
how is it shifting?
i ran dry for almost 4 days, car was shifting very bad, i cheak it empty as anything can be.
Then i drained the old fuild out, then put fresh fuild in with a tranny lube for old transmissions. It shift like normal again then a week later I added a tranny cooler..
the problem is I gotta keep refuilling every 7k miles i have a leak near the block and tranny seal.... too poor to fix.. but 5 bucks not gonna kill me every month tho..
Old Oct 1, 2006 | 02:45 AM
TOAB's Avatar
Make sure everything is at operating temp. Turn off the car. Pull out the stick, wipe it off, put it back in, pull it out... viola!
Check Hondas with the car off.
bbLUDE
Mar 17, 2008 11:38 AM
TurboEM1
23
Apr 28, 2006 04:09 AM
97akwerd
Aug 21, 2005 02:20 PM
turbotime
Aug 17, 2004 08:44 AM
DSC
Jun 30, 2002 01:15 AM
