Brake Fluid, for the clutch. Recamendations.
I need to re bleed my clutch, remove an air bubble from the line. My clutch doesnt feel right and I know the disc isn't worn out. It doesnt slip, the pedal just feels like it should have some more pressure to it.
Anway, what fluid should I use?
Im thinking about that ATE super blue, or maybe just going to pep boys and seeing if Mobil 1 has anything.
I have just always used Motul. But that is just me. Of course, I don't drive an S2000 either.
Mobil 1
AMSOIL
Motul
ATE
All those are some good stuff.
Mobil 1
AMSOIL
Motul
ATE
any dot 4 fluid is fine for street and hpde
read the fine print in the label, there should be a dry boiling point, most of the dot4 is around the area so just pick anything you like.
dot 4 fluid will absorb water in the air faster than oem fluid, so do flush them every two year.
I always use valvoline dot4 synpower, they are cheap and i can get it in every retail store.
the bad thing? they only make it in clear with a hint of light amber, i almost have to bleed out alot of new fluid just to make sure the old juice is completely flushed out.
I flush my every year, bleed everytime it see track action.
oh btw, when you do a complete flush, make sure you bleed it again couple days later, you'll always find some hidden bubble in the line
Its the clutch. Are you a drag racer? Do you do clutch dumps repeatedly? I bet you could use water and it wouldn't boil.
Just get any DOT3/DOT4 fluid and you'll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthx32 »</TD></TR><TR><TD CLASS="quote">Its the clutch. Are you a drag racer? Do you do clutch dumps repeatedly? </TD></TR></TABLE>
No. No.
No. No.
