What will it take a GSR to rev to 9500 rpm's?
if its stock, then just get a new motor
first the valve train is not designed to take more then 8700rpm without bind or premature wear
cams + the SC usually run out of steam by 8000rpm, so its pointless
at that high rpm even B16Bs can be destroyed if no proper build up was done
9000rpm is possible without a major dent in the wallet but the motor will need to be kept in perfect sync., fuel, timing all has to be perfect
RPM = ruins peoples motors
[Modified by eg6ajk, 9:05 PM 5/1/2002]
a bullet proof block and fully upgraded valvetrain would be recommended..i havent really seen any off the shelf cams that make power that high.
the valve train is more of a problem than the block, 9500 is good for extreme cams like Skunk2 Stage 3's, Toda Spec C's, etc. mostly to keep in the power band after a shift. C-Speed did B16A PR3 pistons in a B18C1 (11.3:1 CR) with Portflow inner/ITR outter valve springs and portflow Ti retainers (about 320 before shipping) and said it was good to 10K rpms. The Vortech supercharger would probably make power up that high, but not the JRSC. In that case, you would want lower CR pistons, but the same valvetrain upgrades, VERY good fuel tuning, and some praying to your respective religion. HTH.
-Andrew
-Andrew
Higher RPM = more stress on parts
So to alleviate stress on parts you will need to get lighter yet stronger bottom end components - lightweight cold forged rods and lightweight pistons, and good crank bearings.
The top end will require high performance cams, matched springs, retainers, lighter & stronger valves, and P&P head work.
That's the minimum work neccessary to raise the rpm significantly.
ITR rods and CTR or ITR pistons will go safely to 9.5K.
-Andrew
-Andrew
information like what you are saying can seriously damage peoples motors.
-Andrew yea....you do that and rev up to 9.5k and tell me what happens.
-Andrew
possible yeah, i have a friend who takes hi ls-vtec to 9500 on the STOCK LS RODS! hes at 12.1 compression but i'm waiting to see for how long
Edit: its a good motor but not balanced, lubricated, supported or has the b/s to live that high w/o major work that basically mimics a b18c and such
[Modified by tonydatyga, 9:43 PM 5/5/2002]
HONDA RR
Nov 6, 2004 10:14 PM
StinkyTofu
Mar 24, 2002 09:48 AM
nsx-Animal
Sep 20, 2001 12:50 PM
