new clutch problems after install!
Old Sep 29, 2006 | 07:08 PM
midnitesol's Avatar
Default new clutch problems after install!
i have a 95 del sol with a gsr w/ ctr tranny. i put a stage 3 clutchmasters with fidanza flywheel and the first time i started it i shorted something n 2 fuses blew causing my gauge cluster not to work. i replaced the fuses and started it but it would die once in a while when the cel came on and the car died for a second. we had to replace a plug so those wires must be backwards but also its hard as hell to get into gear, when off it goes in fine when on its kinda hard and i gotta force it in. sometimes i cant get in 1st at all. i've searched n think it might be the throwout bearing but any input is greatly appreciated!
Old Sep 29, 2006 | 09:09 PM
wattsdc2turbo's Avatar
Default Re: new clutch problems after install! (midnitesol)
did you grease the input shaft ?
Old Sep 30, 2006 | 11:05 AM
midnitesol's Avatar
Default Re: new clutch problems after install! (wattsb20)
i actually found today that its leaking tranny fluid im not sure from where i replaced the tranny seal cause it was torn so that should be fine but havent had a chance to lift it back up? also it kinda makes a sorta whistling noise and stops whenever i press the cluth in a little bit also reverse is the easiest one to get into! oh and no i didnt grease the input shaft would that contribute to it too? please help any suggestions greatly appreciated!
Old Oct 1, 2006 | 02:26 PM
midnitesol's Avatar
bump any input is helpfull!
kou-integra98
Oct 3, 2013 03:58 AM
blu3fan
Aug 13, 2010 09:22 PM
nanagsr
Mar 30, 2009 10:26 AM
Team ICU
Aug 11, 2008 01:31 PM
midnitesol
Sep 29, 2006 05:13 PM
