cx/dx compatibility
Old Sep 29, 2006 | 05:07 PM
VegaS10's Avatar
Default cx/dx compatibility
My 95 hatch is getting swapped as I type this. It is a dx with a nice running engine. My friend JUST picked up a 93 cx hatch. Sadly though, it smokes, and it may not make it until he gets his swap late NEXT year.
I am aware that the engine and tranny will literally drop right in, but, since neither is vtec, can we just plug and play with the wiring, or will i need to extend anyting?
I'm trying to help my buddy so all help is appreciated.
TIA.
Old Sep 29, 2006 | 05:14 PM
Syndacate's Avatar
Well do you know why it's smoking?
Old Sep 29, 2006 | 05:30 PM
VegaS10's Avatar
His has about 250-275K miles on it. Has alot of oil on it, and looks messy. Basically, it's a clean shell with a great interior and was a good price.
Mine only has about 125K and never had any problems. I was very meticulous with it and pretty much babied it.
I'm going to give him my old engine and tranny. I'm just researching any wiring issues.
Old Sep 29, 2006 | 07:42 PM
96-EJ6 B18C's Avatar
Default Re: (VegaS10)
The only thing you you will have to change is the O2 sensor, yours is a 4 wire and the CX uses a 1 wire. swap that sensor and its plug n play.
Old Sep 30, 2006 | 04:08 AM
VegaS10's Avatar
Default Re: (96-EJ6 B18C)
Ok, cool.
We use my ECU (I presume). But, won't my ECU searh for a 4 wire O2, or will it be ok with the cx's 2 wire O2?
Old Sep 30, 2006 | 04:18 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegaS10 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, cool.
We use my ECU (I presume). But, won't my ECU searh for a 4 wire O2, or will it be ok with the cx's 2 wire O2?</TD></TR></TABLE>
Yes you will. The CX only has a 1-wire O2. Your O2 is still in your manifold, which is still on your old engine correct?
Old Sep 30, 2006 | 09:07 AM
Bense's Avatar
Default Re: (Mr Hammond)
make sure you change the p05 cx ecu out for the p06 dx ecu
Old Sep 30, 2006 | 09:28 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">make sure you change the p05 cx ecu out for the p06 dx ecu
Word you're ecu will search for the multi-wire.
schardbody's Avatar
you have to run the o2 wires to the ecu or atleast to the shocktower.
sleepydragon636
11
Apr 21, 2019 06:09 AM
shawn_crx
Oct 24, 2009 07:28 AM
AllMotor12s
Apr 21, 2004 04:07 PM
al3e
Jan 13, 2004 06:04 AM
pagong
Oct 18, 2003 03:30 PM
