OBD2b 3 wire Alternator to OBD1 4 wire help - searched
Old Sep 29, 2006 | 03:34 PM
Slothy's Avatar
Default OBD2b 3 wire Alternator to OBD1 4 wire help - searched
Im doing a B16 swap in my 99 hatch. OEM alternator is 3 wire: white/blue, black/ yellow, and white red. I've beed searching and all I can find is 4 wire to 4 wire conversion. Im wanting to use the newer 4 wire alt. Is there any way to wire it to work?
Thanks
Old Sep 29, 2006 | 08:20 PM
Slothy's Avatar
Default Re: OBD2b 3 wire Alternator to OBD1 4 wire help - searched (Slothy)
I've tried to use my 3 wire D-series, but the belt adjusting bracket doesn't line up
(circled)
Can I go:
Blk/Yel -- blk/yel
Wht/ blu -- wht/blu
blue -- red
and disregard the whte/ yellow -- wht/ green (I do not have the white/green)
Thanks again.
Old Sep 29, 2006 | 08:53 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
what harness u using?
Old Sep 30, 2006 | 03:28 AM
Slothy's Avatar
Default Re: OBD2b 3 wire Alternator to OBD1 4 wire help - searched (rukawa1one)
99 harness, canadian model civic cx hatch.
Old Sep 30, 2006 | 04:12 PM
Slothy's Avatar
Just disregard the final wire (wht/yel), car will charge fine without it. No CEL.
Just use the 3 wires mentioned above, no problems
Old Nov 8, 2024 | 09:19 PM
SlowClean_Ej8's Avatar
Soo say I’m going from 4 wire to 3 wire would I still do the same thing and disregard the (why/yel) wire? Also the harness that I have with the 4 wire connector that I’m trying to convert to three wire has (blk/yel) (wht/red) (wht/grn) (wht/blu) I’m also going to be trying to convert the distributor connector connector which is a big square connector currently and hopefully will be converting it to rectangular connector soo if anyone has any info on that I’d greatly appreciate any help and advice on how to go about doing that!! Thanks in advance!! Pictures below for reference!!
4 pin alt connector
4 pin alt connector
Big square distributor connector
Different connector on harness but this is what my current distributor connector on harness in car looks like
What my current distributor connector on harness in car looks like from another angle!
wwolf771177
Feb 4, 2014 02:25 PM
aznryd3r
Nov 24, 2006 10:05 AM
dpw41285
Nov 13, 2004 12:29 AM
LostCRX
Mar 8, 2004 12:58 PM
