HELP!!!! SPARK PLUG FAILURE ON A RUNNING ENGINE "PICS INSIDE"---------------------------------------
Old Sep 29, 2006 | 02:43 PM
b16civster's Avatar
Default HELP!!!! SPARK PLUG FAILURE ON A RUNNING ENGINE "PICS INSIDE"---------------------------------------
SO i was having this trouble at low rpms with no ign in a chamber.so i thought it was the dizzy like every other broblem in a honda b series motor........nope theck this **** out...
any help would be great....what kind of damage could this have done????
IT RUNS MINT NOW GOT MY PWR BACK
Old Sep 29, 2006 | 02:58 PM
b16civster's Avatar
Default Re: HELP!!!! SPARK PLUG FAILURE ON A RUNNING ENGINE "PICS INSIDE"-----------------------------------
did the tips melt or break????? by the way there [ngk bkr6eix-11] plugs
Old Sep 29, 2006 | 03:57 PM
ne3ek's Avatar
those look lean! What's your ign timming at?
Old Sep 29, 2006 | 04:04 PM
b16civster's Avatar
29* at 8199rpm it has been tuned to 13.5:1
Old Sep 29, 2006 | 04:12 PM
ne3ek's Avatar
do you have a wb?
Old Sep 29, 2006 | 04:14 PM
b16civster's Avatar
oh ya
Old Sep 29, 2006 | 04:26 PM
ne3ek's Avatar
so what are you thinking it is? a mechanical failure? You think the piston hit? I'd imagine it'd cause lots more damage than that! It really just looks like it detonated. but if you're tuned and rock a wideband then ionno
Old Sep 29, 2006 | 04:45 PM
b16civster's Avatar
it was only on cylandar 2+3
Old Sep 29, 2006 | 04:51 PM
ne3ek's Avatar
3 was the cyl that died on my last ls/v.. a little piston + spark plug lovin.. I don't condone that sort of thing.
I'd pull the new plugs right now and see how they look/what color they are after a good rip
Old Sep 29, 2006 | 05:48 PM
b16civster's Avatar
yah just got back from a good rip w/my girl...ill check in the morning... its good to be back in the beast (waiting on a dizzy for 2 weeks)and with the new plugs it pulls like no tomorrow (for what it is)
but bump for more input
Old Sep 29, 2006 | 07:46 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16civster &raquo;</TD></TR><TR><TD CLASS="quote">did the tips melt or break????? by the way there [ngk bkr6eix-11] plugs</TD></TR></TABLE>
if they broke, where did the tips go? i hope safely through your exhaust valves.
a friend of mine had 12:5 CP pistons and they kept hitting the plugs just enough to close the gap and stop running. didn't break the tips. ended up getting shorter plugs. i would imagine there be more damage to your plugs if the piston made contact and the tips broke. could they have really melted?
Old Sep 29, 2006 | 08:16 PM
b16civster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote"> could they have really melted?</TD></TR></TABLE>
thats the golden question
Old Sep 30, 2006 | 08:19 AM
b16civster's Avatar
bump
Old Sep 30, 2006 | 10:40 AM
b16civster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16civster &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Old Sep 30, 2006 | 12:24 PM
b16civster's Avatar
bump again because a ton of peeps looked but only 2 posted
Old Sep 30, 2006 | 12:32 PM
b16sedan's Avatar
Press the little button with the flower on it on your camera before you take close up pics of stuff like that. Macro makes us be able to rell what is actually going on.
Old Sep 30, 2006 | 01:03 PM
b16civster's Avatar
hope this helps
Old Sep 30, 2006 | 01:35 PM
GSRCRXsi's Avatar
looks like it broke off to me. doesnt look melted.
Old Sep 30, 2006 | 02:23 PM
ne3ek's Avatar
DEF breakage
Old Sep 30, 2006 | 03:50 PM
b16civster's Avatar
but why on #2+3 cylendar
Old Sep 30, 2006 | 05:53 PM
d16dcoe45's Avatar
Are those Iridium plugs? Did you gap them? Alot of these Iridium plugs are not supposed to be gapped--its the way the ground electrode is constructed that makes it prone to breakage if you bend it by gapping.....The burn looks ok--that is physical damage.
Old Sep 30, 2006 | 11:59 PM
b16civster's Avatar
yup them bitches where gapped **** i cant believe i had to find out the hard way
Old Oct 1, 2006 | 09:26 AM
ghostskinner's Avatar
running too much timing
Old Oct 1, 2006 | 10:36 AM
b16civster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostskinner &raquo;</TD></TR><TR><TD CLASS="quote">running too much timing </TD></TR></TABLE>
if i was running too much timing there would be more or actually A sign of detination witch i dont even see
BizKut77❤myCB7
Engine Management and Tuning
Apr 27, 2017 08:57 AM
mugen94
Aug 25, 2009 07:24 AM
dynimitejack
Aug 15, 2008 03:11 PM
a1320honda
Sep 4, 2007 10:04 AM
Krnbk2
Aug 25, 2004 06:02 AM
