Installing a tachometer
Old Sep 29, 2006 | 02:25 PM
Raider504's Avatar
Default Installing a tachometer
I want to install a tachometer in my 94 civic EX. I want to mount it on the center dashboard above the aur condition vents, will I have to drill holes in the dash?
Old Sep 29, 2006 | 03:21 PM
BlueIntegraBoy's Avatar
Default Re: Installing a tachometer (Raider504)
Yes, you'll need to screw in the base of the tachometer, which will make holes in your dash. Depending where you are going to run the wires, you might need to drill a hole to run the wires under the dash. Remember, measure twice and drill once.
Old Sep 29, 2006 | 06:07 PM
ctrld-kaos's Avatar
Why not go with a jdm or udsm cluster that already has a tack? No drilling or wiring required...
Old Sep 29, 2006 | 06:14 PM
kaoss_11's Avatar
B A N N E D
Default Re: (ctrld-kaos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctrld-kaos &raquo;</TD></TR><TR><TD CLASS="quote">Why not go with a jdm or udsm cluster that already has a tack? No drilling or wiring required... </TD></TR></TABLE> Probbaly because they are not nearly as accurate as lets say a autometer tach or defi gauges
Old Sep 29, 2006 | 06:21 PM
ctrld-kaos's Avatar
Default Re: (kaoss_11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote"> Probbaly because they are not nearly as accurate as lets say a autometer tach or defi gauges </TD></TR></TABLE>
True, but I still wouldn't drill, cut or modify my dash in any way shape or form. Beside that, those big *** autometer tachs tend to gain unwanted attention. To each his own though.
Old Sep 29, 2006 | 06:39 PM
MurdersV8s's Avatar
True. cops and thieves are attracted to tachs and guages.
Old Sep 29, 2006 | 06:41 PM
hyper209's Avatar
one day your car will get jacked......... ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Old Sep 30, 2006 | 02:37 AM
Because his car already is an EX with a tach.
bluecivic05
Jun 17, 2006 06:01 AM
TITAZ05
Honda Civic (2001 - 2005)
May 10, 2006 07:39 PM
EKIM NART
12
Apr 23, 2006 08:15 PM
Jmorin
Feb 21, 2004 06:48 PM
hawks10
Apr 5, 2002 01:26 PM
