f4i owners, need some one to look at wheel on there bike
Old Sep 29, 2006 | 12:40 PM
7808's Avatar
Default f4i owners, need some one to look at wheel on there bike
i just put new tires on my 03 f4i now my wheel seems off center in the forks.
the side with the longer spacer (throttle side) seems to have more space between the wheel and the forks on that side. tryin to figure out if this is a problem or not.
its easy to tell by looking at the clearence between the rotor and and fork, or standing over the front looking down its not perfect in the middle of the fender
Old Sep 29, 2006 | 01:12 PM
ASteele2's Avatar
Default Re: f4i owners, need some one to look at wheel on there bike (7808)
do the discs slot in OK? Then you're fine.
Old Sep 29, 2006 | 01:53 PM
ngng's Avatar
did you put the spacers back on the axle?
Old Sep 29, 2006 | 02:17 PM
MSchu's Avatar
My Name is Nobody
Default Re: f4i owners, need some one to look at wheel on there bike (ngng)
or if the spacer is sloted it may go on backwards or the wrong side of the bike
Old Sep 29, 2006 | 02:25 PM
.RJ's Avatar
.RJ
Your wheel is on backwards.
Old Sep 29, 2006 | 07:02 PM
7808's Avatar
Default Re: f4i owners, need some one to look at wheel on there bike (.RJ)
my wheel is not on backwards.. the spacers are in there, brakes are on fine. spacers dont seem to be slotted. its not alot but its easy to see and bothers me
Old Sep 29, 2006 | 08:00 PM
marmaladedad's Avatar
Does it fit better with the spacers switched?
Old Sep 30, 2006 | 07:57 AM
BusaWill's Avatar
Make sure the spacers are in the right way.I had the same problem with mine
Old Sep 30, 2006 | 08:41 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">my wheel is not on backwards.. </TD></TR></TABLE>
Ok, well I had the same problem with my F3. I had put the wheel on backwards.
Old Sep 30, 2006 | 11:27 AM
ASteele2's Avatar
My F4 looks like it could be off a little, but it's not. FWIW.
Old Oct 2, 2006 | 11:20 PM
7808's Avatar
Default Re: f4i owners, need some one to look at wheel on there bike (ASteele2)
so the spacers can be fliped around ? cause they look like there the same either way you put them in as long as its the right side
Old Oct 3, 2006 | 03:04 PM
The spacers on the F4i can be flipped. Just be sure to clean the gunk off.
ZexyAccord
Honda Motorcycles
May 11, 2007 05:13 AM
modulo_s
Honda Motorcycles
13
Sep 7, 2006 11:01 AM
Rednas
Honda Motorcycles
14
Jun 14, 2006 03:01 AM
VTHokie
Honda Motorcycles
Sep 2, 2005 06:48 AM
Nextelbuddy
Honda Motorcycles
12
Jul 15, 2003 06:20 PM
