How to maintain 100,000+ Honda Accord?
Old Sep 29, 2006 | 11:23 AM
jaspaly's Avatar
Default How to maintain 100,000+ Honda Accord?
We have a Honda accord with milage around 101,000. We would like to know details of service and other maintenence we need to do regularly. The car is in a very good condition and at what milage we need to do major and minor services.
Thanks in advance,
J
Old Sep 29, 2006 | 12:23 PM
Slunk's Avatar
Default Re: How to maintain 100,000+ Honda Accord? (jaspaly)
If you have the manual (edmounds.com has it too) it should have some guidelines in it. Overall though by now you should have the timing belt/water pump changed by now.
Old Sep 29, 2006 | 12:33 PM
timmy0tool's Avatar
i've read to change the timing belt and water pump with all the associated seals every 90k miles.
what year is your car?
Old Sep 29, 2006 | 01:59 PM
hondaccord's Avatar
Default Re: (timmy0tool)
I thought it is suppose to be 60k
Old Sep 29, 2006 | 04:16 PM
YeuEmMaiMai's Avatar
for 1998-02 cars the V6 belt is to be changed every 105K under normal driving conditions and every 60K under severe
Old Sep 29, 2006 | 04:27 PM
richardtires's Avatar
my 96 Accord has 68,000...
Old Sep 30, 2006 | 05:52 AM
C_H_A_D's Avatar
Default Re: (richardtires)
Spark plugs,wires and distributor. If they are original I would go ahead and change that out.
New air filter might not hurt.
Old Oct 1, 2006 | 05:06 PM
AccordInTheMaking's Avatar
Definetly follow the preventative maitinence procedures and the scheduled repair procedures.
Also for a long running accord change your oil OFTEN. If it says you can go 7,500 i still do mine every 3,000 with high quality oil, filter, and Lucas additive ( I would rather put good stuff in my car and know that it will never cause a problem than use cheap stuff and not know what its doing). And remember oil never goes bad... its the additives they add to it that go bad. Change your oil OFTEN. Honda's live "forever" with good oil and when they're taken care of.
Old Oct 1, 2006 | 08:15 PM
WhiteOnRice's Avatar
Change the oil...
Well, seriously the only major thing I would be concerned about is the condition of the timing belt. Mine has 119,000 miles, has no mechanical problems, and see's the red part of the tach a couple times a day...
Old Oct 2, 2006 | 05:51 AM
standbackimapro's Avatar
100,000.. is nothing
A friend of mines mom has a 90 accord with, 200k + Miles on it, And the only thing they replaced was the transmission
As for Maintenance on that mileage accord
IF you havnt Already replaced the Distributor then youll need to do that soon, because ive owned 3 accords and all of them have had a distributor fail around 100k-130k
Change all the fluids, Radiator, Transmission, Oil,
IIf the Transmission is manual it takes gear Oil so i would Put 2 Lucas transmisson Fixes in it then the rest Some High Quality Gear oil, i usually use Mobil 75w90
Same thing with an automatic, Just Instead of gear oil use transmission fluid with 2 lucas transmission fixes
Also if its stick, It May Be time To Replace The clutch
Timing Belt, Water Pump
Old Oct 2, 2006 | 07:02 AM
Acco12dv6's Avatar
Default Re: (standbackimapro)
01 accord v6
114,900 miles
What exactly is the distributor and what does it do? Expensive to change? I have changed the timing belt and water pump, along with alternator belt and crankshaft pully belt. I flushed the coolant also.
Old Oct 2, 2006 | 07:28 AM
conker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">100,000.. is nothing</TD></TR></TABLE>
This pic is a couple of months old, up to 306,000+ now.
The big ones (killers) are timing belt every 60-90k depending on driving conditions and oil. I did oil every 3,000 miles for years but have backed off to 5k because I am logging about 500 miles a week. Everything else:
- tranny fluid
- plugs, cap, rotor
- coolant
is on about a 50k schedule unless it looks bad or car is acting cranky.
These are not factory recommendations but following them and keeping a sharp eye and ear on things has worked for me for 14 years. This car is the best money I ever spent.
Old Oct 2, 2006 | 07:29 AM
future62
Guest
Posts: n/a
Default Re: (Acco12dv6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acco12dv6 &raquo;</TD></TR><TR><TD CLASS="quote">01 accord v6
114,900 miles
What exactly is the distributor and what does it do? Expensive to change? I have changed the timing belt and water pump, along with alternator belt and crankshaft pully belt. I flushed the coolant also. </TD></TR></TABLE>
The distributor sends electricity to the spark plugs. I'm not sure why but they have to be changed every so often. I changed mine about 10k miles ago...
But yea...basic stuff is just the timing belt, air filter, ignition stuff, radiator flush, tranny oil/fluid, etc. Just maintain it and it will run forever, I rag on my car almost every day and when I really beat it up it takes it like a champ and keeps pulling.
Old Oct 2, 2006 | 08:06 AM
Acco12dv6's Avatar
Default Re: (future62)
Does the 01 v6 accord have a distributor or is it called something else?
Old Oct 2, 2006 | 08:30 AM
jakeiscool's Avatar
Banned
i have 160 on mine with no problems. h22 swap though.
xemi
Oct 17, 2018 08:03 AM
ek02
17
Sep 23, 2018 09:08 PM
Ord4
Sep 21, 2013 03:10 AM
stevescivic
Apr 15, 2008 11:46 AM
94HondaAccord_LX
Jan 3, 2008 03:46 PM
