A question for all of you Tech Experts =)
Old May 1, 2002 | 04:10 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default A question for all of you Tech Experts =)
This article has got me thinking http://www.speedoptions.com/news_hot...earch&v=1&pg=0
Would it be possible to swap in a B18C in my integra ls (just the long block), keep my current auto tranny, and run the car off the JDM B16a auto ecu or the jdm B18C si-r auto ecu? If this is possible what will be needed to make it work?
No flames please
Old May 1, 2002 | 09:14 PM
-=TWITCH=-'s Avatar
Default Re: A question for all of you Tech Experts =) (FrostyDC4)
read some of the replies, its funny some of those people are real tools or my word that I love fucktards
Old May 2, 2002 | 01:04 PM
Katman's Avatar
No flames please
ok. no comment on the linked article.
but yes, you can mate an auto b-series LS tranny to a b-series vtec block. you'll need to swapp all the at clutch components (flywheel etc) over and yes, run a JDM Auto ECU. I suspect you have an OBD1 (94-5) LS, correct?
Old May 2, 2002 | 01:52 PM
EVOCELICA's Avatar
New User
Default Re: A question for all of you Tech Experts =) (Katman)
Couldn't he also use his stoock ECU and just wire in a vtec switch
Old May 2, 2002 | 03:33 PM
Katman's Avatar
Default Re: A question for all of you Tech Experts =) (EVOCELICA)
he could but that's actually a temporary remedy to get vtec to work. The correct way is to actually use a vtec ecu on a vtec engine and take advantage of the vtec fuel maps when vtec kicks on. you follow? The stock non-vtec ecu doesn't have the same fuel maps as a vtec ecu does. you follow?
Old May 2, 2002 | 08:13 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
No flames please
I have a obdII 96 LS but I am thinking about running a obdI ecu. What will I need for the obd2 to obd1 conversion? Hey Katman do you carry the JDM Auto P72 and if you do how much do you sell them for (obd1&2)?
Old May 3, 2002 | 08:17 AM
speedymon's Avatar
Default Re: A question for all of you Tech Experts =) (-=TWITCH=-)
hahhahaha....."get an aluminum wing" Fawwkin ricers.
Old May 3, 2002 | 02:33 PM
Katman's Avatar
check your IM...
szczerbanator
Jun 1, 2009 12:29 AM
dwn2earth922
May 25, 2007 09:02 PM
Spins
May 27, 2004 07:23 PM
FrostyDC4
May 2, 2002 01:24 PM
wuhungsixxx
Aug 14, 2001 09:49 AM
