Skunk2 pro cams?
Old Sep 29, 2006 | 08:46 AM
hondadriver's Avatar
Default Skunk2 pro cams?
Are the Skunk2 Pro series cams Pro 1, Pro 2, Pro 3 more aggressive than the skunk2 stage 1, 2, 3 cams?? I know you can install The stage one cams on a stock valve train but you'll need springs for the stage 2's and 3"s. What about the Pro cams, can you install the Pro 1 cams in a stock valve train?
I though the Pro series cams replaced the original stage 1-3 cams, but I read posts about these cams and people are saying to use the stage 1's on a stock compression instead of the Pro 1's.
Can some one please explain the difference in these cams. i tried the search function for the last 2 days, but i keep getting search fail!
Old Sep 29, 2006 | 08:49 AM
GSRCRXsi's Avatar
Default Re: Skunk2 pro cams? (hondadriver)
yea search is fucked for some reason.
the pro 1's are bigger then the stage 2's DONT use them with stock valvetrain. only the stage1's are ok on that
Old Sep 29, 2006 | 09:19 AM
BABY NSX's Avatar
Default Re: Skunk2 pro cams? (GSRCRXsi)
Any Skunk2 Pro series cam requires upgraded valvetrain components...
Old Sep 29, 2006 | 11:47 AM
Default Re: Skunk2 pro cams? (BABY NSX)
Thanks guys. I have a set of zex(comp) stage one cams in my B16a now. but over the winter I would like to get a set of stage 2 skunk or zex cams. I know i should replace the springs, but i don't want aftermarket srpings, because over the years I've read about aftermarket springs breaking. So what i wanna do is use a new set of oem USDM type r exhaust and intake valve springs. Do you think using the USDM Integra Type R valve springs will be good enough for a set of stage 2 skunk or zex cams (what ever I decide to buy). And i will only rev to stock redline.
Old Sep 29, 2006 | 12:28 PM
GSRCRXsi's Avatar
no. the lift is too much. you NEED aftermarket springs for the stage2 cams.
Old Sep 29, 2006 | 12:32 PM
Dat1BVtecN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">no. the lift is too much. you NEED aftermarket springs for the stage2 cams. </TD></TR></TABLE>
Old Sep 30, 2006 | 11:06 AM
Default Re: Skunk2 pro cams? (Dat1BVtecN)
So should I get the Skunk2 springs that skunk recommends for the cams? Or could I use a spring from a different manufacturer thats probably alot better quality.. And Do i need retainers? I read a post a while back about a skunk2 retainer snapping in half. So i'm not sure if i'm gonna go with skunk2 parts at all. I might go with Zex stage 2 or blox b cams (been seeing more and more posts about them)!!!
where can i get a spring comperessor to remove the springs while the head is on the car?
Old Sep 30, 2006 | 04:03 PM
DonF's Avatar
You read too much bad info. Go with E-Bay they have no bad reports.
Old Oct 1, 2006 | 09:11 AM
Default Re: Skunk2 pro cams? (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">You read too much bad info. Go with E-Bay they have no bad
reports.</TD></TR></TABLE>
Thats dumb! answer my question or don't post. What the expletive. If you know more them me fine, tell me whats good and whats not, or how I should or shouldn't do something!!!
Old Oct 1, 2006 | 09:14 AM
GSRCRXsi's Avatar
acting like that you might as well search and find out for yourself. lol. its back up anyway.
Old Oct 1, 2006 | 10:30 AM
ACTING LIKE WHAT??? The first question i asked was answered!!!! But I have some other questions, I put up my other question and got
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">You read too much bad info. Go with E-Bay they have no bad reports.</TD></TR></TABLE>
What kinda a **** is that!!! i mean seriously, i read alot of posts some dumb some good, after I read them i move on!! Unlike some people that NEED to type dumb **** like that ^. If you don't have an answer, don't type.
Old Oct 1, 2006 | 10:59 AM
dohcMONSTER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadriver &raquo;</TD></TR><TR><TD CLASS="quote">ACTING LIKE WHAT??? The first question i asked was answered!!!! But I have some other questions, I put up my other question and got
What kinda a **** is that!!! i mean seriously, i read alot of posts some dumb some good, after I read them i move on!! Unlike some people that NEED to type dumb **** like that ^. If you don't have an answer, don't type. </TD></TR></TABLE>
haha calm down, DonF could rip off your head and **** knowledge down your neck if he wanted to. My advice would be to search around and read in this forum there is a lot of good info here
BLU CIVIC
Nov 8, 2009 07:24 AM
Fresno_NSX
Apr 1, 2005 09:46 PM
codeh22a4
Sep 21, 2004 02:27 PM
98TypeSH
Apr 14, 2004 11:54 AM
riceball777
Oct 19, 2003 09:53 PM
