vtec pressure code??????????????? help
Old Sep 29, 2006 | 08:28 AM
myallmotoreg's Avatar
Default vtec pressure code??????????????? help
I got a 98 b18c5 in my eg. everything is fine except that when i get into vtec for a while (like in third) it throws code 22. I ve checked the screen on the vtec gasket and its good. vtec works so the wiring should be ok. I live in a small town and no one can help. any body have an idea.
p.s. im new so go easy
Old Sep 29, 2006 | 11:57 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: vtec pressure code??????????????? help (myallmotoreg)
do you have the vtec pressure switch hooked up? I didn't notice if you mentioned is the B18C a JDM motor? If so some do not come with these sensors and you have to get one and install it.
Old Sep 29, 2006 | 12:59 PM
Default Re: vtec pressure code??????????????? help (HondaPartsHero)
it is a jdm motor and i looked and its not there so that must be the problem. so now what switch could i use, i have one off of my jdm d15b (obd1) would that work. my itr is obd2 and so is the engine harness but im running a obd1 p28. will an obd1 switch work. also do i have to drill and tap a hole or should i buy a new silonoid (cant spell sorry). What do think? and by the way thanks
Old Sep 29, 2006 | 06:19 PM
JasonST's Avatar
Think I found ur problem. Obd2 engines don't use the Vtec pressure switch, only obd1 engine's do. So that's why ur getting the cel for it, cause ur ecu is looking for it when it's not even suppose to be there on ur obd2 engine. So ur fine, if the cel gets annoying just get an obd2 ecu.
Old Sep 29, 2006 | 07:02 PM
Default Re: vtec pressure code??????????????? help (JasonST)
when the cel goes off it disables my vtec how do i fix that
Old Sep 30, 2006 | 09:39 AM
JasonST's Avatar
I think u're going to have to get an obd2 ecu. Are u saying when the codes comes on it disables ur vtec or when it turns off?
Old Sep 30, 2006 | 09:47 AM
aj99si's Avatar
you can use any vtec pressure switch they are all the same. It will screw directly into the vtec solenoid you already have. so just use the one from the d15b and call it a day.
jayeghatch
14
Sep 25, 2012 02:19 AM
TheSickestDC2
Dec 7, 2009 02:29 PM
f2m0u5
Apr 13, 2006 08:32 PM
dyloazn
Apr 12, 2006 06:49 PM
Absubtle
Jul 3, 2005 09:48 AM
