NEED HELP: engine wont start
Old Sep 29, 2006 | 08:04 AM
IIDIEIV619's Avatar
Default NEED HELP: engine wont start
engine rotates but wont start. 86 CRX Si EW-4 1.5L 4 cyl.
when it sits for at least a day it will start, but after it warms up then i turn it off it wont start again. this is weird and im having trouble diagnosing this problem.
any info would help. i posted a thread earlier this week but didnt get much replies. so if you can help please fill me in.
Old Sep 29, 2006 | 08:07 AM
65stang90crx's Avatar
Default Re: NEED HELP: engine wont start (IIDIEIV619)
Try replacing main relay. It causes all kinds of problems like that.
Old Sep 29, 2006 | 08:13 AM
IIDIEIV619's Avatar
Default Re: NEED HELP: engine wont start (65stang90crx)
COULD IT BE THE FUEL PUMP? HOW CAN I CHECK TO BE ALMOST POSITIVE THAT ITS THE MAIN RELAY. THE ONLY REASON IM ASKING IS CAUSE IM ON A BUDGET AND I DONT REALLY WANT TO HAVE TO REPLACE THINGS THAT ARENT REALLY THE PROBLEM BUT IF I HAVE TO THEN SO BE IT. THANKS
Old Sep 29, 2006 | 08:25 AM
When you turn the key to the "ON" position (not "Start") do you hear the fuel pump whin for a second and build pressure? I doubt that it sitting a day then trying again and it starting would be fuel pump, maybe.
Old Sep 29, 2006 | 08:35 AM
IIDIEIV619's Avatar
WELL I TRIED TO LISTEN FOR IT BUT I CANT HEAR ANY SOUND. WHAT I ALSO DID WAS DISCONNECTED THE HOSE TO THE FUEL RAIAND TURNED THE KEY "ON" TO SEE IF I GOT ANY PRESSURE. BUT NONE. POSSIBLITIES ARE FALLING SOMEWHERE WITH THE FUEL DELIVERY IM GUESSING. THE MAIN RELAY ALOS KICKS ON THE FUEL PUMP RIGHT?
Old Sep 29, 2006 | 08:39 AM
NO NEED FOR CAPS I CAN HEAR YOU FINE. Yeah, that narrows it down to one of the two. Try the main relay seriously thats probably what it is. And you have the totally take the tank down to change the fuel pump (Well unstrap it most the way). If it turns out to be the fuel pump then a walbro 255 is my suggestion.
Old Sep 29, 2006 | 08:45 AM
crx2nr822's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 65stang90crx &raquo;</TD></TR><TR><TD CLASS="quote">NO NEED FOR CAPS I CAN HEAR YOU FINE.</TD></TR></TABLE>
LOL
Old Sep 29, 2006 | 08:46 AM
IIDIEIV619's Avatar
Lol...yeah excuse the Caps. im here at work and our system uses only caps. so i have to remember to take them off. but anyways back to the subject, is there a way i can check the main relay? do you have anything else in mind that i should do to try and figure this problem out? and by the way thanks for the suggestions, i appreciate the help.
Old Sep 29, 2006 | 08:48 AM
JOE BD-0's Avatar
https://honda-tech.com/zerothread?id=1032246 - how to test your main relay
good luck
Old Sep 29, 2006 | 08:56 AM
Default Re: NEED HELP: engine wont start (JOE BD-0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOE BD-0 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1032246 - how to test your main relay
good luck</TD></TR></TABLE> Great thread, I was just looking for it. Thanks
Old Sep 29, 2006 | 09:15 AM
IIDIEIV619's Avatar
Swwwweeeeet!
Old Oct 2, 2006 | 06:39 AM
Default Re: (IIDIEIV619)
Update on getting that problem solved?
Old Oct 2, 2006 | 10:42 AM
IIDIEIV619's Avatar
Default Re: (65stang90crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 65stang90crx &raquo;</TD></TR><TR><TD CLASS="quote">Update on getting that problem solved?</TD></TR></TABLE>
I tested the relay and had no continuity. so i ordered one today. i tried the junk yards and wasnt sure if any other model had a relay that was compatible with mine so i just pulled two off another 1st gen crx and with my luck i took it home ran the test and sure enough they were faulty too. so today i ordered a brand stankin new one to be installed today. so ill keep you updated. Thanks for your help
Old Oct 2, 2006 | 12:32 PM
No problem man. If you still have problems I'll be watching this thread.
Old Oct 3, 2006 | 08:37 AM
IIDIEIV619's Avatar
okay, i replaced the main relay with a NEW one and still nothing. im thinking its time to play the Elimination game. so im replacing the pump today. this is getting to frustrating and eventhough i dont have the money to spend im a spend it anyways somehow
Old Oct 3, 2006 | 08:40 AM
Like I previously stated, if you are replacing the fuel pump go with a walbro 255 lph. It will make life a lot easier if you end up swapping. And they are fairly cheap $100.00
Old Oct 3, 2006 | 11:29 AM
IIDIEIV619's Avatar
where can i find a walbro 255 at? if i used a test light to test the connector going to the fuel pump and it is dim, it is a sign of weak voltage or was the pump only suppose to be recieving a small amount...i dont know i thought id ask?
by the way thanks alot bro.
Old Oct 3, 2006 | 11:50 AM
There should be a 12v surge to the fuel pump only for a few seconds after turning the key to on, after that I dont think that there should be any (Until you start your car obviously ). Walbro 255LPH http://cgi.ebay.com/ebaymotors...wItem Just an example, you dont have to buy that one. It fits right into the old spot fairly easy. Im not sure exactly how much voltage should go to the fuel pump. Maybe a HondaMaster here will respond and tell you.
Old Oct 11, 2006 | 11:54 AM
IIDIEIV619's Avatar
CHANGED THE FUEL PUMP AND BABY STARTED WITH NO PROBLEMS...THANKS FOR HELP YOU SAVED ME MONEY AND TIME...I OWE YOU ONE SO LET ME KNOW IF YOU NEED ANYTHING..THANKS
DA9b0y303
29
Aug 21, 2013 03:51 PM
bimmeracer
Feb 11, 2008 10:19 AM
White98LS
Jul 14, 2007 07:46 AM
MJPana
Jul 30, 2006 09:27 AM
CRU
Sep 14, 2004 11:07 AM
