Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tire Rub
Old Sep 29, 2006 | 06:52 AM
R18A1FG's Avatar
Default Tire Rub
I have got 225/45/17's on my FG1, my techs nor I can figure out why Im getting tire rub over bumps, its a common size for the FG's, the car is lowered but only 1.2-1.5, just curious if anyone else out there is having the problems or not.
Old Sep 29, 2006 | 06:55 AM
Type X's Avatar
Default Re: Tire Rub (R18A1FG)
whats the specs on your rims?
width? offset?
Old Sep 29, 2006 | 07:02 AM
R18A1FG's Avatar
Default Re: Tire Rub (Type X)
17 by 7's
offset is +42mm
Old Sep 29, 2006 | 04:24 PM
boostedlude97's Avatar
i'm lowered on S-tech's and i've got 225-45's on my stock si wheels. driving normally i'm not worried but when i go over bumps faster than i should it rubs just a little bit.
Old Sep 29, 2006 | 04:59 PM
R18A1FG's Avatar
Default Re: Tire Rub (boostedlude97)
yea, exactly, but its not even a matter of going faster than i should, sometimes i slow way down, i was just curious how many people were expiriencing this since its a recommended size for 17s
Old Sep 29, 2006 | 05:14 PM
56civic's Avatar
i've got 18s with S-Techs and i would also rub on some bumps, but that went away after i got an alignment done. so it could be an alignment thing.
Old Sep 29, 2006 | 08:30 PM
Default Re: Tire Rub (56civic)
my car is straight as an arrow....
Old Sep 30, 2006 | 01:40 AM
dpao6's Avatar
seems like a lowering problem then. My rims are 17x7.5, 42mm offset, 225/45-17 tires, not lowered, no rubbing, not even with four adults.
Old Sep 30, 2006 | 06:54 AM
projectprelude's Avatar
dude i have the same problem....im lowered on sportlines with 235/45/17s......sucks
Old Sep 30, 2006 | 01:24 PM
R18A1FG's Avatar
Default Re: (projectprelude)
hahaha thats awesome though that you put 235's on there, if im getting rubbing with 225's i know you must be!!
get me a pic from a rear angle of your car on wanna see see those on there
Old Sep 30, 2006 | 01:44 PM
Declectic's Avatar
daymn, 235 is pretty wide compared to the stock 215
Now I've heard/read or whatever that the same rim specs on an FG1 vs and FG2... the FG1 would have issues where as the FG2 would not (issues meaning rubbing, bumping, etc...) ... does this question make sense? and if it does .. can anyone answer that?
Old Sep 30, 2006 | 07:37 PM
haby red fg2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectprelude &raquo;</TD></TR><TR><TD CLASS="quote">dude i have the same problem....im lowered on sportlines with 235/45/17s......sucks</TD></TR></TABLE>yours are rubbing cause your tire is also to tall it is 3/4" to tall just an fyi
i have 225 on my stock wheels its not lowered but when i was in the process of moving and had the car packed and the wheels were just about tucked i had no rubbing at all
Old Oct 1, 2006 | 07:29 AM
R18A1FG's Avatar
Default Re: (dys3767)
well I guess we need to hear from more people that have a dropped FG running 225/45/17's or something in the same overall diameter!
bo0st lee
Acura TSX
Jun 1, 2007 10:45 AM
Shmaa
Jun 2, 2006 02:48 PM
jfingers
Mar 24, 2004 06:38 PM
Blackhorse6
Feb 16, 2004 10:02 PM
